Results 1 to 10 of 10
Thread: Water temp
    Aug 2019
    Ohio
    Water temp
    Looking for opinions...I have a ‘16 k 1600 gtl. As you know there’s a bar graph on dash for water temp. Every since it was new it ran, depending on weather at 2 to 4 bars, average 3 bars. It would have to idle quite a while before it would get warm enough to kick the fan on. I just recently had the 18k service done which included removing the radiator & flushing the cooling system. Now the bike runs at 5 bars & will go from dead cold to 5 bars within a mile. It will also climb to the point to kick the fan on every time I stop at a couple stoplights. I went back to dealer, they said there was an air bubble in system & it was fine now. Bike still runs at same temps. I just recently completed a 2000 mi trip with no overheating problems, but I can’t help to feel like there something restricting the flow, not letting the coolant circulate properly. Has anyone else experienced anything similar?
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    My 2012 GT runs between 4 & 5 bars rock steady in normal riding.
    Never noticed how long it takes to get up to temp.
    Joe
    “Fate whispers to the warrior, 'You cannot withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Apr 2006
    Nibley, UT USA
    I’d ask if the coolant system was refilled using a vacuum tool. That’s the only way to guarantee no air entrapment in the head passages.
    Edit: Also, verify that coolant level is correct in the reservoir...
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    Aug 2019
    Ohio
    Quote Originally Posted by GTRider View Post
    Best,
    DeVern
    Thanks.. Not sure about vacuum tool. I think fluid level look high but after 2nd visit they stated everything was correct.
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by marv-lou View Post
    Well, I don’t claim to be a certified tech or an engineer and I didn’t sleep at a Holiday Inn last night, but IMHO the symptoms you describe would certainly be in line with having an air pocket trapped at a sensor location—but I have no idea where the K16 mounts it’s sensors. And if there is air trapped in the system and fluid in the reservoir, the fluid level is moot—the system will never draw in fluid and relieve the problem. If the situation is really bothersome you may want to treat it as you would a medical issue and get a second opinion by having the fluid drained and refilled using the factory-recommended vacuum tool, possibly by another dealer. That’s a reasonably-priced way to scratch that possibility off the list.
    Good luck,
    DeVern
    DGerber
    Aug 2019
    Ohio
    Good luck,
    DeVern
    Thanks so much. Will look into that
    Aug 2019
    Ohio
    What temps are your k 1600’s averaging ?
    Registered User jonnybow's Avatar
    Apr 2019
    Delaware
    I have a 2014 and it always runs with 4 or 5 bars, it's never been cooler or hotter for long periods of time. It has been up to 8 bars in extreme conditions but normal operations, it is solid at 4 or 5 bars.
    Jon
    K1600GT & R1200GSA
    BMW MOA #220293
    Mehrten
    Nov 2004
    Arizona, USA
    Our 2019 K1600GT Sport is a 5 bar temp bike.
    It comes up to 5 bars in short order and generally/usually stays right there.
    In hot, slow moving conditions it will go up to 8 bars with the fan coming on either at 7 or 8 bars.
    All the K bikes I've owned will get into the hot zone when in slow moving traffic in lower gears when the temps are above freezing ;)
    Aug 2019
    Ohio
    Ok thanks guys. Guess maybe mines ok then
  1. /6 cylinder temp
    By skotlyc in forum Airheads
    Last Post: 06-18-2015, 04:52 PM
  2. 92 K75S - water temp light question
    By heejrbmw in forum Flying Brick K-bikes
    Last Post: 06-01-2015, 02:08 PM
  3. Oil temp gauge
    By 154048 in forum Airheads
    Last Post: 01-31-2010, 05:20 PM
  4. water/oil pump water seal
    By jamesbruce in forum Flying Brick K-bikes
    Last Post: 05-26-2008, 07:12 PM
  5. Low Oil Temp in the Rain...
    By HFD190 in forum Oilheads
    Last Post: 07-25-2007, 02:00 AM
