Results 1 to 15 of 15
Thread: Nasty noise coming from the rear today . . .what is it?
    Noticed a nasty sound while riding today. Parked it and took this video. New to BMWs (F700gs) so maybe someone can identify this for me? Thanks so much!
    Greg
    MOA #218215
    2015 F700GS
    Mansfield,MA
    Have you looked at the parts breakdown? If it has the pie shaped rubbers that act as a bit if a cushion-drive that the F800GS has......Sounds like they have gone a bit dry and hard and are flopping around.
    Not hard to check really. Good time to check the wheel bearings while your in there.
    Mod Squad
    2009 F800GS 1994 TW200
    Sep 2012
    Lansing, Kansas
    Sounds like it only knocks when the wheel is turned backwards, at least what I heard on the video you attached.
    Sorry, I can't help since my ST has a belt drive and I've never heard anything like this.
    Good luck.
    Royce
    On the coast of Kansas
    2012 F800ST
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    GasEx. The solution for nasty rear end noises.
    Kevin Huddy
    gig harborr ,wa
    rear end
    Sound like the four rubber wheel dampers. Hold the sprocket and chain from moving then try moving the wheel forward and back. You should not be able too. Then take the rear wheel off and check dampers and bearings.
    Lost again Texpaul's Avatar
    Oct 2006
    San Antonio, Tx
    You don't say how many miles on the bike, especially the rear sprocket.
    The rubber bumper check is good advice but there are three other possibilities. The rear wheel bearings, the rear sprocket and the chain. I seem to remember having to redo the rear wheel bearings on my wife's 650 twin at somewhere around 60K. If the rear sprocket is very worn the teeth may be snagging on the chain as the wheel is rotated backwards (wouldn't make that noise rotated forward). Check the chain for a kinked link.
    Paul Mulhern
    MOA# 56330
    The biggest mistake people make... is thinking they have time.
    Removed the rear wheel and the bearing inside the sprocket hub fell out in pieces . . . damn. Ordered new bearings and will have to make a trip to a dealer for a once over and install.. Hope I didn't do any nasty damage.
    Greg
    MOA #218215
    2015 F700GS
    Mansfield,MA
    Not sure if this is common to your bike
    https://forums.bmwmoa.org/showthread...gs-on-a-F800GS
    May give you some ideas.
    Mod Squad
    gig harborr ,wa
    What was the condition of the dampers?
    gig harborr ,wa
    Omega Man ,so I see you have been down the bearing path before.
    Mansfield,MA
    Quote Originally Posted by EUGENE View Post
    Yeah, been down a lot of paths
    On that path there was a problem but wasnít where I thought it wuz
    Mod Squad
    Dampers were good. Intact and no noticeable wear. I am really surprised by the bearing disintegration. I have ridden many cycles in my lifetime and have never had this type of problem. Especially at mileage less than 6k. This bike was pre-owned so I donít know what the previous owner might have done to cause such a failure.
    Greg
    MOA #218215
    2015 F700GS
    gig harborr ,wa
    mileage
    You never did say what the mileage was???
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    but he did say "at mileage less than 6k"
    gig harborr ,wa
    I miss something.
  1. noise coming from ?
    By galaxie in forum Airheads
    Last Post: 01-05-2019, 08:30 PM
  2. "Clunking" noise coming from rear drive area
    By dkjkwood in forum Wedge K-bikes
    Last Post: 09-12-2014, 01:22 AM
  3. What's the awful noise coming from my rearend?
    By 90288 in forum Flying Brick K-bikes
    Last Post: 08-30-2005, 02:05 AM
  4. I won't be coming in today...
    By burnszilla in forum Flying Brick K-bikes
    Last Post: 01-17-2005, 11:39 PM
