Results 1 to 5 of 5
Thread: r50/2 FRONT wheel bearing stack removal
    Mar 2019
    San Francisco
    looking for some advice about removing the bearing stack
    i have the hub cover off but i am not certain what to do with the axle bushing
    ausherman mentions this but when it is removed the axle just slides through the hub
    any help?
    thanks
    Liaison 20774's Avatar
    Can you upload some pictures showing where you currently are? IIRC I thought the axle was reversed to the opposite side and then the stack can be driven out. Duane usually has good info on this.
    Mar 2019
    San Francisco
    i got the stack removed and cleaned up and regreased.
    always use the rear axle to drive out the stack
    with the front wheel the bushing spacer must be removed
    that is why you need to use the rear axle because the front axle is thinner
    i did find that one side of the stack was a French bearing
    maybe there is hope for humanity
    thank you Richard from benchmark bmw parts for your sage advice
    Glad you got things worked out! Richard and Vech are great even on the phone.
    Focused kbasa's Avatar
    I learned by watching this video from the nice folks in Illinois. I followed their lead and it was a piece of cake.
    Dave Swider
    Marin County, CA
  1. r50/2 FRONT wheel bearing stack removal
    By tinkerer in forum Airheads
    Last Post: 08-25-2019, 10:22 PM
  2. 1972 BMW R75/5 - Wheel Bearing Stack
    By b25bsaboy in forum Airheads
    Last Post: 11-15-2018, 03:53 AM
  3. R75/6 rear wheel bearing stack.
    By Jeff488 in forum Airheads
    Last Post: 09-24-2015, 10:53 AM
  4. Wheel Bearing Stack w/No Bearing
    By bostonmish in forum Airheads
    Last Post: 08-13-2010, 12:01 PM
  5. Front wheel bearing PM
    By twins4life in forum Oilheads
    Last Post: 08-16-2006, 01:40 PM
