Results 1 to 15 of 18
Thread: Hill Stop Activation
    Well, purchased a 2018 RT with Premium Pkg which I understand has Hill Stop on it. Strangely I'm not able to get it to activate on this bike. I watched a YT video where a GS activates it on an off road hill and I realize now that you have to squeeze the brake handle until the symbol is displayed on the dash. I squeezed it quite hard today and held it for at least 10 seconds and no activation symbol. I have the original MSRP sticker and it shows that Hill Stop is on this VIN, but can't figure out how to get it to work. What am I doing wrong? Or, do I need to see the dealer.
    TIA
    Liaison 20774's Avatar
    TIA -
    Welcome to the forum!! I did a search and came up with a few past threads:
    - different bike but might help - https://forums.bmwmoa.org/showthread...ll-Hold-How-to
    - another for ideas - https://forums.bmwmoa.org/showthread...ssist-2017-GSA
    Registered User powwow's Avatar
    Aug 2015
    Bend, OR
    Unless it's changed on the 2018, squeezing and holding the brake lever until is how I activate the Hill Stop on my 2015 RT.
    I frankly don't use it very often...I'm so used to just keeping my foot on the rear brake pedal to hold the bike in place.
    Larry Gregerson; Bend, OR
    MOA #93031
    Wow...can't believe that was my first post to the MOA group. I've joined so many forums lately since getting my first BMW, I guess I can't keep them straight. I've from Spokane, and as I mentioned this is my first BMW. So surprised it wasn't a car as I've lusted after a 3-Series for ages.
    Have had the bike for almost 2 weeks and 800 miles. Really enjoying the technology compared to my T120. Suspension on the RT is best to date for me and she is very nimble indeed.
    BTW...TIA is Thank in Advance and not my moniker So thanks for the input.
    Finally, nice to be part of the community and look forward to participating. Will be doing my own MX, so I'm sure this is a valuable resource.
    Registered User WWeldin's Avatar
    May 2018
    Lilburn, GA
    You can turn the feature on and off in the menu with the wonder wheel. I remember reading about it somewhere in my owner's manual, but after a quick glance, I did not find that specific part. See if you can scroll though the menu on the bike.
    2000 R1200C, 2019 R1250RT
    I think you have to kind of quickly "double-squeeze" it. Quickly squeeze, release and squeeze and hold hard/lots of pressure. Sorry for some uncertainty, but I haven't used it much. This was talked about very recently, maybe in a different forum, and that's when I figured out I even had it. I didn't have to change any settings. Releasing its hold takes a bit of getting used to.
    OP here. Well I figured this one out. Seems I was expecting the indication to light up on the middle panel where the ABS, etc indicators are. Well the hill stop indicator is a small circled H right next to the gear position number in the same color as the gear indicator (White). It is so nondescript that I just didn't notice that it was on. As I said, I expected it to be a red indicator in the middle panel. In the training world we call that tunnel vision, or channelized attention. More to learn I'm sure.
    Mar 2011
    socal
    Once you get used to hill stop, you will find yourself using it all the time
    May 2018
    Lilburn, GA
    On my RT, I can feel it activate the rear brake through the brake pedal. I usually know where on my commute that this is activated so I am watching the circle H turn green at the same time I can feel it throught the rear brake pedal. Sometimes I deactivate it by a foot tap on the rear brake just before I ride away. Not needed, but in some situations I have it off until traffic behind me is actually stopped.
    Glad you sorted it out.
    Registered User skibumwi's Avatar
    Jul 2016
    Milwaukee
    Quote Originally Posted by WWeldin View Post
    To disengage I usually use a light tap on the front brake, that's all it takes. I've also read that some people are having trouble with taking off from a standstill with the Hill assist engaged. As long as I know that it's on I don't have an issue, but it does require more throttle. If I've engaged it accidentally I usually come very close to stalling out.
    Enjoy the bike, I can't think of another bike I'd rather own.
    Ski
    Jan 2016
    Arvada, CO
    Quote Originally Posted by emersont View Post
    Not for a '16 wethead--you simply squeeze it enough and quickly and it's in HS. To release, either give it enough RPM while letting out the clutch, or just give it another quick squeeze and it releases. If you're double squeezing you just aren't giving it enough with the first quick firm squeeze. Just takes a few times of getting it correctly to get the feel of it. I use it every time I ride whenever I want to let go of the right grip at any kind of stop.
    I'm not a fan of the Hill Start Assist on my '16 RT. While the concept is really good, I need to feed it it a huge fist full of throttle to get it to release, and therefore prefer to use the "old school" method of holding on the foot brake.
    I use hill start assist and love it. As for taking off from a dead stop I use it like this. The 'how to' part comes about the 4:00 mark. I was using this method before and now I use the HS instead of holding the bike back with my legs. This guy has some nice videos.
    Tom
    2019 RT
    Mar 2011
    socal
    Here’s a question! With hill start engaged is brake light on?
    Quote Originally Posted by t6pilot View Post
    I just checked on my '16 RT. With Hill Start engaged, the brake light is on.
  1. Hello from South Hill, VA
    By thelazyc in forum New Members
    Last Post: 11-30-2015, 12:38 AM
  2. iABS Phantom Activation of Brake Light and Servo
    By DougRaymond in forum Oilheads
    Last Post: 07-23-2014, 01:42 AM
  3. How many stop at a stop sign............???
    By motorman587 in forum Motorrad
    Last Post: 07-08-2013, 01:06 AM
  4. Always a full stop for stop signs?
    By BCKRider in forum Just Ridin'
    Last Post: 12-12-2011, 05:56 AM
  5. We go to the Hill Climb
    By 99007 in forum Ride Reports
    Last Post: 09-21-2004, 01:37 AM
