Results 1 to 11 of 11
Thread: Do you have a CyclePump air compressor
    I always carry a tire pump with me, and I check my tires regularly when I travel. I currently have a Slime portable pump, and it works great as a portable compressor. However, I don't like the attachment mechanism. I have an RT with the 90 degree valve stems. To attach the pump I have to lay on the ground, reach under my bags, use one hand to push the attachment onto the valve stem while I use the other hand to activate the pressure switch to secure the hose to the valve stem. Really, really don't like doing this.
    I've been looking at the CyclePump from Best Products. It appears to have a straight chuck with what looks like a simple to use, one handed attachment mechanism. Although it's expensive, I'm willing to pay the price if i can simply reach down with one hand and easily secure and attach the hose to my valve stem. But if I still have to reach down with one or both hands to fiddle with it to get it to attach securely, I'll simply stick with my reliable Slime portable pump.
    If you have a CyclePump can you tell me how easy it is to attach the hose to the valve. Is it easily and realiably done with one hand consistently.
    Thanks for your help, Don
    Easy, simple, reliable.
    Registered User powwow's Avatar
    Aug 2015
    Bend, OR
    I've had a Cycle Pump compressor for many years and, like Paul says, it's simple and reliable. However, it's been relegated to the pannier of my dirt bike and replaced by a Motopressor for my RT:
    https://www.rockycreekdesigns.com/pr...ssor-mini-pump
    The Motopressor works great and I love the feature of setting the desired pressure so it turns off automatically. With the Cycle Pump, I had to continually stop, check the pressure, then either start again or let some air out.
    You can't go wrong with either one.
    Larry Gregerson; Bend, OR
    MOA #93031
    Mar 2011
    socal
    Cyclepump for the last 6 years, great piece of gear
    Not cheap, itís been 10% reliable
    Geeser mcover's Avatar
    Nov 2006
    Annapolis MD
    only 10%? mine is 100% reliable.
    if you use their pressure gauge there is no need to stop, check pressure, and continue
    Marty
    2016 K1600GTLE
    2016 R1200GSA
    IBA #575
    Mar 2011
    socal
    My mistake, itís been 100% reliable
    Aug 2015
    Bend, OR
    Quote Originally Posted by mcover View Post
    My bad...you're correct. I do use their pressure gauge.
    However, for a lot less money, the Motopressor has been fantastic.
    MOA #93031
    AZ
    One more option is MotoPumps. Very small and has a port to connect your gauge to it while you fill.
    MOA #107139
    RA #28511
    Smile Thanks
    I want to thank everyone for the helpful responses. Regards, Don
    sMiling Voni's Avatar
    If you haven't seen this you need to . . .
    Voni
    sMiling
    BMW MOA Ambassador Emeritus / FOM / Roving Forum Moderator/
    Selected Friends of Wile E Coyote/ A Million 100 thousand BMW sMiles
    Had one, but not a fan of the clip hose attachments. Chews up the valve threads and hard for me to get a consistent sealed connection. Pump itself is great.
    Tom Barrie
    http://bluegrasspicker.blogspot.com/
    2012 K1600GTL
    2002 R1150RT (sold)
  1. CO2 or compressor?
    By PoorUB in forum Gear
    Last Post: 06-11-2019, 03:11 AM
  2. Thanksgiving Sale at Cyclepump
    By mikegalbicka in forum Gear
    Last Post: 11-29-2018, 09:14 PM
  3. CyclePump inflators on sale.
    By Omega Man in forum Gear
    Last Post: 04-21-2017, 02:09 AM
  4. Replies: 7
    Last Post: 11-01-2015, 04:11 AM
  5. Air compressor
    By PineGreen in forum Gear
    Last Post: 03-02-2012, 11:15 PM
