Results 1 to 7 of 7
Thread: Replacing clutch parts. '07 R1200RT
    Sep 2015
    My home is 1 Mile from Cromwell, MN
    Question Replacing clutch parts. '07 R1200RT
    I have been servicing airheads since 72 including clutch repairs.
    Am wondering if I should attempt similar work on my Hexhead. Is it much more difficult?
    rod Walli
    Jul 2013
    Solvang, CA
    Quote Originally Posted by 43082 View Post
    rod Walli
    go for it...can't be much different than my 13RT that i just did...a little tedious but very doable in about 10-12hours
    ~wyman~
    Sep 2013
    Central Maine
    Pretty simple, the 10 to 12 hours is an accurate time frame for your first go at it. The only issues I had were not having enough hands to put the wiring back around the rear frame as I was mating it back up with the engine. Good luck, post some pictures if you can.
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    I did mine and I'm no mechanic.
    I followed the instructions on the BMW RSD DVD with no issue
    I'm not that fast, it took me over 20hrs to do it. (Took my time and some pictures to make sure it looked the same as before after putting it back together...)
    I replaced the OEM clutch disc with a heavy duty oil & heat resistant kevlar disc.
    You need two people to separate and reconnect the two half of the bike. (I did)
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Quote Originally Posted by Dann View Post
    Is it sufficient to replace the clutch disc (and I'm guessing bolts), or do the other parts of the clutch also need to be replaced when clutch is worn out?
    Sep 2013
    Central Maine
    Clutch and pressure plate recomended
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by jandhumphreyme View Post
    + 1
    That's what I did
    Daniel
  1. Replacing the K1300 S clutch pack
    By hmeiseles in forum Wedge K-bikes
    Last Post: 09-21-2017, 04:37 PM
  2. Replacing pushrod seals 1971 R75/5 (Parts List)
    By motomark in forum Airheads
    Last Post: 01-19-2016, 08:47 PM
  3. Hints for replacing clutch on R1100 GS
    By MUSICMAN in forum Oilheads
    Last Post: 03-07-2010, 04:43 AM
  4. replacing rubber parts
    By tthouses in forum Airheads
    Last Post: 10-12-2009, 12:14 PM
  5. Replacing clutch cable
    By sumran in forum Airheads
    Last Post: 01-11-2008, 01:09 PM
