I have been servicing airheads since 72 including clutch repairs.
Am wondering if I should attempt similar work on my Hexhead. Is it much more difficult?
rod Walli
I did mine and I'm no mechanic.
I followed the instructions on the BMW RSD DVD with no issue
I'm not that fast, it took me over 20hrs to do it. (Took my time and some pictures to make sure it looked the same as before after putting it back together...)
I replaced the OEM clutch disc with a heavy duty oil & heat resistant kevlar disc.
You need two people to separate and reconnect the two half of the bike. (I did)
Thanks to all for the encouragement. I am somewhat meticulous so my guess it may take a bit longer than 12 hours.
I also need to do something about the ABS system which is intermittent ... works well if temp s below fifty degrees, until I hit a bump.
Thanks again, Rod
Thanks again, Rod
rod Walli
rod Walli
Did you accomplish your task?
