Hi all,
Question about tensioning the chain on my 2014 Sertao. I’ve read through the manual and can see the sticker on the side of the swing arm stating the tolerances, however, I can’t for the life of me make out whether the measurement should be made center-to-center on the same pin, top of a plate when the chasing is depressed to bottom of a plate when it’s lifted, or in some other fashion. Looks like the tolerances are fairly tight, or at least tight enough that when I measure one way tension is off, measured the other it’s still within tolerances. Any advice greatly appreciated!
~Josh
~Josh
