Results 1 to 12 of 12
Thread: Chain tension question
    Jun 2019
    Vermont
    Hi all,
    Question about tensioning the chain on my 2014 Sertao. I’ve read through the manual and can see the sticker on the side of the swing arm stating the tolerances, however, I can’t for the life of me make out whether the measurement should be made center-to-center on the same pin, top of a plate when the chasing is depressed to bottom of a plate when it’s lifted, or in some other fashion. Looks like the tolerances are fairly tight, or at least tight enough that when I measure one way tension is off, measured the other it’s still within tolerances. Any advice greatly appreciated!
    ~Josh
    Jun 2009
    Rochester, MN
    I go same point to same point and always on the looser side of the range.
    Webbike World Recommends: "always measure the lower run of the chain; that is, the length of chain that runs along the bottom of the sprockets, not the top run."
    After messing with it for a while, I broke down and bought a Motion Pro Slacksetter Pro.
    CENTEX USA
    Don't over complicate your life
    I have used the push the lower run of chain up in center between wheel and engine, ours averages about 1" of travel at that point...when I tension it, maybe 1/2" or whatever the sticker/ manual shows for that model.
    Our 650 GS holds value a long time...my KTM690 doesn't
    Bigger issue is to lube regularly to extend life and avoid banjo tight adjustments that stress the chain.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Keeping a chain clean is also an important part of keeping a chain healthy.
    Kevin Huddy
    Mansfield,MA
    Hard use can cause a chain to have a bit different “stretch” in different points. Once satisfied, you can have a look at the “sag” in different parts of the chain run.
    All in all, the modern chains are pretty fool proof. Short of being able to lift off the sprockets, you should be good to go.
    Mod Squad
    2009 F800GS 1994 TW200
    CENTEX USA
    Quote Originally Posted by akbeemer View Post
    Seen at local Kawa dealer
    Jun 2019
    Vermont
    Thanks All
    Thanks everybody for the info. I come out of the world of bicycles and was a mechanic for years. Cleaning and lubing regularly are part of my maintenance regimen for sure. Oddly enough, when I asked my dealer what they recommend for cleaning the chain, the response was “we don’t recommend cleaning them.” He said because the chains are sealed with o rings and such, any cleaning is merely aesthetic. I disregarded that suggestion and went ahead with cleaning using wd 40, which was what I always used for bicycle chains. After all, they’re the same thing, just smaller. Again, thanks for the thoughts!
    Mansfield,MA
    I try to go easy with the WD-40 as it really penetrate and can wash past the O-rings. WD-40 on a rag-
    Mod Squad
    Jul 2007
    Big Sky Country
    I use a WD40 on a sacrificial rag so as to not get enough WD40 on the chain to worry about penetration.
    Kevin Huddy
    Jun 2009
    Rochester, MN
    Quote Originally Posted by jasper650 View Post
    I'd also disregard the advice not to clean your chain - they aren't nearly as cheap as a bicycle chain. However, a bicycle and motorcycle chain are not the same thing... there aren't any o-rings (or x-rings) on a bicycle chain (and therefore no grease). The additional friction from an o/x-ring setup would be quite a bit to overcome for a normal cyclist.
    Fortnine did a nice comparison about which cleaner is best:
    gig harborr ,wa
    chains
    This is good info.
    I mix ATF with 90w gear oil and use a small paint brush and use this to "wash" the chain so to speak and use a rag to get the chain as clean as possible after application. I do this fairly often as after a ride it only takes a couple minutes. I am all about protecting the cogs and also replace chains before most would. I do the same with all the bicycles but I use a thin oil for the bicycles and don't do it after every ride though I do lightly wipe after a ride.
    Cleanliness is key and replacing the chain before it stretches and ruins the cogs.
    Signature
  1. Cam Chain Tensioner question??????
    By rbertalotto in forum Wedge K-bikes
    Last Post: 06-21-2011, 08:08 AM
  2. timing Chain Question
    By habdala in forum Airheads
    Last Post: 10-28-2009, 01:27 AM
  3. Chain question
    By awagnon in forum Thumpers - F & G bikes
    Last Post: 08-28-2008, 11:36 PM
  4. 650GS Chain question
    By downhillhunter in forum Thumpers - F & G bikes
    Last Post: 10-06-2006, 10:07 AM
  5. Cam chain rattle question
    By twins4life in forum Oilheads
    Last Post: 10-24-2005, 08:49 PM
