Results 1 to 6 of 6
Thread: R75/5 Siebenrock
    R75/5 Siebenrock
    Hi All-
    Just purchased a Sieberock 1000cc Kit for my 73R75/5 LWB. I recall reading somewhere about the use of two base gaskets below the jugs as a way to lower compression, etc. Im not inclined to do it, but just curious as to why some have chosen this method and whether it does seem to have merit.
    Thanks for your comments!!
    Tom
    Liaison 20774's Avatar
    Tom -
    I did a Siebenrock replacement for my R100/7, so not a displacement upgrade, but there was an increase in compression ratio with the new parts. I got my kit from Ted Porter. We talked about this. The CR went from stock around 9.1:1 to about 9.5:1. I felt that was too much of an increase and didn't want to consider dual plugging. So, Ted suggest I install a base gasket that was meant for the R60 series...it was 0.67mm thick as I recall. He indicated it dropped the CR to around 8.9:1. That was good enough for me.
    The stock R75/5 was 9.0:1 so you would be in about the same situation. The /5 part number for the R60/5 was 11111257092. Check with your provider for something if you want to go this direction.
    Siebenrock Kit
    I believe the Siebenrock kit uses the same pistons as Motoren Israel sells.
    I installed the Motoren Isreal forged pistons (1st over) on my high mileage R90s a few years ago. They were advertised as stock, 9.5:1 pistons. But I decided to measure all the volumes of the heads, cylinders, etc. and came up with 9.0:1. Sometimes, you have to do your own verifying.
    RPGR90s
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    I lowered the compression on one of my R75s - it lost a little bit of power (not a big deal when you're just touring on an R75...), but the engine got a little smoother and it was a LOT less fussy about what gas I put in it.
    Aug 2006
    Grover Beach, CA
    Anyone know of a good resource on where to learn how to install a Siebenrock Big Bore 1070cc kit on an R100? I have an 83 RT that I am trying to restore. I'd like to turn it in to a old airhead hotrod. I've watched tons of youtube videos but no one discusses how to do the entire 1070cc kit. I've seen plenty of videos on how to upgrade/replace the cylinders and push rod seals but nothing discussing how to replace a camshaft or discuss what else is involved in this project. Thanks in advance for your input.
    skibum69 skibum69's Avatar
    Dec 2016
    New Melbourne, NL
    I want to put an 860 kit in my R65 LS. Time and $$ as always.
    http://beerthief.ca
    ITSteve: ride in peace my friend
    save $5 on a new SmugMug account, use this coupon7frrnSRiTt9Fk
  1. R65 Siebenrock Kit
    By tlangman4 in forum Airheads
    Last Post: 01-18-2019, 04:25 PM
  2. Siebenrock Big Bore Kit
    By tonyo in forum Airheads
    Last Post: 11-06-2013, 10:26 PM
  3. Siebenrock Instructions
    By TGEORGE143784 in forum Airheads
    Last Post: 10-29-2011, 06:12 PM
  4. Updated Siebenrock Web Site
    By rozemab in forum Airheads
    Last Post: 12-31-2010, 10:44 PM
  5. TK50 top box by Siebenrock?
    By CaptDistraction in forum Flying Brick K-bikes
    Last Post: 09-22-2005, 06:16 PM
