Results 1 to 6 of 6
Thread: Ilium Works Engine and Bag Guards
    Registered User Ragman2's Avatar
    Sep 2018
    Lincoln University, PA
    I just had my 6K service done last Friday and also had the Ilium Works engine and bag guards installed. On my way home, I noticed a vibration (at about 50 mph) that was not there before. I seem to remember reading something about this after someone installed engine guards.
    For you who have made this install, have you noticed this?
    I looked up and saw a running bear. Why do you ask Two Dogs....
    I have the Illium front engine and rear (saddle bag) guards installed on my 2018 RTW. I haven't noticed any particular vibration. Of course getting off a K75S and then riding the RTW does cause one to notice the difference in vibration (the K75S is as smooth as glass.) But, the boxer motor on the RTW seems pretty smooth as does the one on my oilhead (R1100RS) {after adjusting the valves to the proper clearances and re-syncing the throttle bodies - following the re-torque of the head bolts - following a replacement of a leaking head gasket - prior to that the oilhead definitely had a worrisome vibration, not so much now.}
    You could try this -
    Check that fasteners are tight
    Loosen fasteners so that the guards find their "natural" position, then re-tighten all to a proper torque.
    Following are some guides for recommended torque values for metric fasteners -
    https://www.boltdepot.com/fastener-i...ed-Torque.aspx
    https://www.swtc.edu/Ag_Power/diesel...e%20values.pdf
    https://crafter.fastenal.com/static-..._Fasteners.pdf
    https://www.imperialsupplies.com/pdf...rqueCharts.pdf
    Sep 2018
    Quote Originally Posted by robsryder View Post
    Thanks!!! I will try that this weekend.
    Registered User gsinnc's Avatar
    Charlotte, NC
    I only have the rear bag guards and love them. But I believe I have heard when folks were installing the Illium Works Front Engine guards they could touch the motor and needed to be adjusted. If that is happening that could very well cause a vibration. I would check all the point on the front guards where they may touch.
    Just a thought.
    Ed Apelian
    Motorcycling is my passion because golf is far too dangerous!
    2018 R1200GS - Light White !
    2016 R1200RT- Platinum Bronze
    Registered User stooie's Avatar
    Aug 2018
    Salem, OR
    Ragman:
    Yes; the front bars are close to the engine and if not adjusted properly can rub and probably cause some noise and/or vibration.
    Hopefully your dealer gave you the Illium installation instructions. If not, Illium's website has a pretty darn good video on doing the installation including the recommended torque values. You don't mention which model you have. Here's a link to the instructions for the RT
    https://www.youtube.com/watch?v=TFsU3yCUt7g
    If you don't have the printed Illium installation instructions for the RT and want a copy, PM me your email address. I'll scan my copy and send it to you as a jpg file.
    Ride safe, have fun.
    Bob Stewart
    Salem, OR
    2018 RT
    Tucson, AZ, & Madison, WI
    I have not noticed any additional vibration.
    Jeff Dean
    Tucson, Arizona, and Madison, Wisconsin
    Co-founder, 1972, of BMW MOA -- http://bmwdean.com/r1200rtw.htm
    2017 R1200RT, 2019 R1250RT, 1967 R60/2
  1. R1250RT Ilium engine guards
    By bmwdean in forum Wetheads
    Last Post: 03-03-2019, 04:25 PM
  2. Replies: 23
    Last Post: 10-17-2018, 12:35 PM
  3. Ilium Engine Guards
    By jogitu in forum Straight 6 K1600 GT/GTL/B
    Last Post: 07-18-2012, 05:26 AM
  4. Replies: 4
    Last Post: 03-31-2012, 02:07 PM
