Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: Air Filter
  1. #16
    https://motorcycleinfo.calsci.com/FilterXRef.html
    Oil filter information.
    Anyone ever hear of K&N Air Filters? That's what I'm going to put in after another 15k miles or so on the stock one. Then I'll probably sell the bike before I look at the air filter again.
    Where do you put the gas cap while filling?
  2. #17
    Aug 2018
    Fargo, ND
    Quote Originally Posted by mojoman View Post
    The answer is not Amazon because I already looked there.
    I might be mistaken, but,
    https://www.amazon.com/MAHLE-Origina...omotive&sr=1-1
    From the only real Fargo, ND!
  3. #18
    Tutum amicus r184's Avatar
    Jan 2008
    So Cal
    Quote Originally Posted by wichitagreg View Post
    Same here. One of the first things I change on every car, truck and motorcycle I've owned. Will prob. outlast the vehicle.
    No Matter Where I went, There I was...
  4. #19
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by PoorUB View Post
    That's the wrong filter for a Wethead.
    The correct number for a Wethead Mahle air filter is LX3595
    Lee
    2016 R1200RS
    MOA # 30878
  5. #20
    Aug 2018
    Fargo, ND
    Which is available on Amazon.
  6. #21
    Left Coast Rider
    Nov 2011
    I've got a couple of ideas for you.....
  7. #22
    May 2003
    SW Iowa
    I just wanted to make sure someone did not order the wrong filter.
    Lee
    2016 R1200RS
    MOA # 30878
  8. #23
    Apr 2006
    Nibley, UT USA
    [QUOTE=Lee;1176351]The K1300S has two air filters and BMW recommends changing every 24,000 miles.
    It didn't take long to get at the filters so I blew them out at 12,000 and changed at 24,000 miles.
    And the K1200GT/K1300GT have ONE of those filters. I blow them out at 6k and replace at 12k, but in adverse conditions (like riding through bad bug infestations) Ive had to replace them at 6k. It DOES make a difference in how the bike runs.
    Best,
    DeVern
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
  9. #24
    Left Coast Rider
    Nov 2011
    Here's a thought for those of you who abhor the price of air filters or frequently ride through areas of "high bug/air ratios".
    Take some black fibreglass screening material you might use to repair a screen door, cut it to size, wrap it around the air inlet on your motorcycle and secure it with a zip tie. I got mine from http://www.rcrint.com/easyscreen_en.htm
    I did this on my R1100S and on my K1200S with no ill effects and my filters stay much cleaner than previous experience shows. Sorry, no before/after pictures - you're just gonna have to trust me on this.
  10. #25
    Feb 2005
    Trinity, NC
    Quote Originally Posted by BC1100S View Post
    I did this on my R1100S and on my K1200S with no ill effects except that my filters stay much cleaner than previous experience shows. Sorry, no before/after pictures - you're just gonna have to trust me on this.
    That is actually a great solution to keep mice from going into the tunnel to get to your filter for nesting.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
  11. #26
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
  12. #27
    Apr 2006
    Nibley, UT USA
    Id suggest some deep research into the filtration capabilities of the K&N air filters before going that route. While the re-usability is appealing, there are several published analysis on the subject. Here in the desert Southwest, I personally wouldnt buy a used bike that had been run on a K&N for much of its life. Filters are one of the more reasonable expenses in BMW ownership, especially when sourced through places like Beemer Boneyard.
    Best,
    DeVern
    DGerber
  13. #28
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by m_stock10506 View Post
    And some of the bugs I've encountered (especially around the Montezuma National Wildlife Refuge in New York) have been the size of mice.
  14. #29
    Nov 2011
    Central Ohio
    If you don't plan to keep the bike long, and don't care about dirt flowing through, you really don't need to check or change the filter at all. A K&N filter still needs to be cleaned and re-oiled on a regular basis. And it will not filter dust as well as the stock, paper version. I see that their website claims 30,000-50,000 miles before cleaning, but that's probably because their filter is not collecting much dirt.
    I bought a K&N air filter for a 25 year old bike with about 63 thousand miles when the stock part was getting harder to find. I found no detectable change in performance. Six months and about two thousand miles of suburban commuting later, while replacing leaky throttle shaft seals, I found that the previously spotless CV slides were coated with a thick, oily, red layer of dust, as were the air intake boots. The filter and the maintenance kit went in the trash and I bought paper filters thereafter.
    This guy did some very extensive tests to compare air filters, measuring air flow and measuring contaminants that passed through. (Watch the beginning to understand the method, skip the repeated tests, see the results at 34:00) Paper performed best in all but one test of airflow - K&N was best on that test, while also being 2nd worst (of 6) for passing contamination on that same test.
    Larry
    2006 R1200RT
  1. K&N Oil Filter
    By BlackMamba in forum Wetheads
    Last Post: 02-01-2016, 03:21 PM
  2. Wix air filter
    By BlackdogGS in forum Hexheads/Camheads
    Last Post: 09-24-2013, 04:59 AM
  3. Air filter
    By GWC in forum Oilheads
    Last Post: 05-05-2008, 11:00 PM
  4. r11rt oil filter vs r12gs filter
    By maxscycle in forum Oilheads
    Last Post: 10-26-2006, 03:41 PM
  5. K&N air filter
    By Polizeitaucher in forum Gear
    Last Post: 02-04-2006, 02:41 AM
