Results 1 to 5 of 5
Thread: Neutral indicator light delay
    Registered User tibork's Avatar
    Sep 2018
    Minneapolis MN
    I often have the issue of the neutral gear indicator light not coming on after turning the ignition on, have to wait a minute or two until it actually comes on. I even tried shifting gears back and forth - 1st to neutral, 2nd to neutral ... etc - but doesn't appear to help. After about a minute or two however it always works. Anyone has this same/similar problem?
    1994 BMW R1100RS (ABS)
    Quote Originally Posted by tibork View Post
    Some oil has seeped into the switch so the contacts get a little oily. That makes the switch "wonky" as you have observed. I do think that shifting in and out of neutral helps wipe the contacts cleaner but the only real fix is to replace the switch.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Oil will do it, so will riding in a lot of rain ... R&R it.
    Make sure you get the "right" one.
    Sep 2018
    Minneapolis MN
    Thank you ... Pauls1150: how do I make sure it's the 'right one'? Any trustworthy supplier where I can order from?
    According to the MAX fiche, the switch for a '94 1100RS is p/n 61 31 2 306 519.
    The '93s and earlier use a different one (I think, but don't specifically recall, that the center alignment is different), and of course the 1150s use an entirely different one.
    I don't know how closely their fiche correlates with the Actual Build Date, though...
    Best bet would be to take the old one to the dealer (Leo's, Moon, Richfield) with you to match it up, or if you're not close to a dealer, maybe email a close-up photo to your source.
    Maybe time to R&R the oil seal inboard of that, too...?
  1. Replies: 2
    Last Post: 11-13-2018, 12:24 AM
  2. Neutral indicator - 08 RT
    By KevinRT in forum Hexheads/Camheads
    Last Post: 08-26-2014, 05:18 PM
  3. 05 R1200ST - Can not get neutral indicator
    By bonny1969 in forum Hexheads/Camheads
    Last Post: 11-25-2012, 11:39 PM
  4. K75s '90 gear/neutral light indicator
    By plehman in forum Flying Brick K-bikes
    Last Post: 09-08-2011, 10:42 PM
  5. K75 Gear indicator and Neutral light
    By rnowell in forum Flying Brick K-bikes
    Last Post: 06-10-2009, 03:51 AM
