Results 1 to 7 of 7
Thread: Neutral indicator light delay
    Registered User tibork's Avatar
    Sep 2018
    Minneapolis MN
    I often have the issue of the neutral gear indicator light not coming on after turning the ignition on, have to wait a minute or two until it actually comes on. I even tried shifting gears back and forth - 1st to neutral, 2nd to neutral ... etc - but doesn't appear to help. After about a minute or two however it always works. Anyone has this same/similar problem?
    1994 BMW R1100RS (ABS)
    Quote Originally Posted by tibork View Post
    Some oil has seeped into the switch so the contacts get a little oily. That makes the switch "wonky" as you have observed. I do think that shifting in and out of neutral helps wipe the contacts cleaner but the only real fix is to replace the switch.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Oil will do it, so will riding in a lot of rain ... R&R it.
    Make sure you get the "right" one.
    Sep 2018
    Minneapolis MN
    Thank you ... Pauls1150: how do I make sure it's the 'right one'? Any trustworthy supplier where I can order from?
    Apr 2008
    According to the MAX fiche, the switch for a '94 1100RS is p/n 61 31 2 306 519.
    The '93s and earlier use a different one (I think, but don't specifically recall, that the center alignment is different), and of course the 1150s use an entirely different one.
    I don't know how closely their fiche correlates with the Actual Build Date, though...
    Best bet would be to take the old one to the dealer (Leo's, Moon, Richfield) with you to match it up, or if you're not close to a dealer, maybe email a close-up photo to your source.
    Maybe time to R&R the oil seal inboard of that, too...?
    Mar 2010
    Vancouver, B.C. Canada
    Using your VIN number on the Max or RealOEM fiche will normally lead you to the correct parts for your exact bike.
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    I checked the parts fiche too and they show the same part number for models built to 11/93 and the same number from 11/93 so it looks like the earlier models, like the one I have, use the same gear position indicator. They also list an item called connecting line which only is to 11/93, 61 12 2 306 520, anyone know what that is ? It is not shown on the diagram, but listed in the parts.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
  1. Replies: 2
    Last Post: 11-13-2018, 12:24 AM
  2. Neutral indicator - 08 RT
    By KevinRT in forum Hexheads/Camheads
    Last Post: 08-26-2014, 05:18 PM
  3. 05 R1200ST - Can not get neutral indicator
    By bonny1969 in forum Hexheads/Camheads
    Last Post: 11-25-2012, 11:39 PM
  4. K75s '90 gear/neutral light indicator
    By plehman in forum Flying Brick K-bikes
    Last Post: 09-08-2011, 10:42 PM
  5. K75 Gear indicator and Neutral light
    By rnowell in forum Flying Brick K-bikes
    Last Post: 06-10-2009, 03:51 AM
