Results 1 to 8 of 8
Thread: RT Tupperware
    Jan 2015
    Pickering, ON, Canada
    RT Tupperware
    When I changed the battery on my 2014 RT this spring, I had to remove and replace the lower (black) piece of Tupperware that provides access to the battery. Since then, I have been unable to get the mushroom-head peg on the TW to stay in the rubber grommet on the gas tank TW piece. I undo the two screws holding the TW in place and firmly seat the peg in the grommet and then re-insert the two screws. The TW is firm and I think everything is ok, but a day to two later, the peg will be out of the grommet again and the TW is just supported by the two screws.
    I may have caused this problem myself, as for years I have always lubed these pegs and grommets with a silicone grease to ease removal - after I had a peg so thoroughly "bond" to the grommet on my Goldwing that the peg snapped off when removing the side panel which resulted in an expensive replacement. I lube the pegs and tabs on the RT side panels to reduce the chance of me breaking off those notorious tabs when changing the air filter too.
    I've now put the peg into the grommet so many times now that I doubt there is any grease left, but I can remove and clean the grommet if that's the solution...
    Is there a trick to getting these things properly mounted?
    Bob
    2014 R1200RT
    Jan 2015
    RT Tuppware
    Well, it's nice to see that it's not just me...
    Thanks for the links.
    I'll go take a look at the grommet for the slots that other poster refers to. I know I did turn the grommet one of the times I reinserted the peg and it seemed to work better. I'll also check to alignment issues. The bottom screw seems to go into a flimsy piece of metal - maybe that was previously moved out of place.
    Oh well, I'll take it all apart and see what I can discover - the bike needs a good wash anyway.
    Bob
    2014 R1200RT
    Registered User gsinnc's Avatar
    Charlotte, NC
    That grommet spin process did nothing for me. But what does seem to work (as odd as this may sound) is I spray a bit of hairspray on the grommet. The wet spray helps it slip in and then the tacky stuff when dry seems to hold it in place. I also put the grommet in first THEN tighten the other 2 screws. I have also added a nylon spacer to the bottom fastener so it does not move the panel as much when I tighten it up.
    Good Luck!
    Ed Apelian
    Motorcycling is my passion because golf is far too dangerous!
    2018 R1200GS - Light White !
    2016 R1200RT- Platinum Bronze
    Quote Originally Posted by gsinnc View Post
    For many years hair spray has been a favorite for installing hand grips on handlebars. While wet it lubricates and when it dries (it is mostly lacquer) it turns to glue.
    Charlotte, NC
    Ed Apelian
    Jan 2015
    Fixed?
    So, I tried the various suggestions (cleaned the grommet and applied something (didn't have any hairspray!) that was sticky), etc. Nothing seemed to work.
    Went back and decided that maybe the bottom mount (down by the oil level window) was maybe misaligned. It's pretty flimsy and could have been abused (bent out of position) when the bike was last serviced or when I installed the battery. It seemed to be pretty far "in" towards the engine block and so I bent it out, away from the engine block, which also required me to bend the tab on the mount that the screw goes into to get the tab parallel to the side panel surface and then I reattached the panel.
    So far (~400 miles) this seems to have worked - panel seems pretty rigid. Fingers crossed
    Bob
    2014 R1200RT
    Sep 2015
    Birmingham, AL
    On my RT, it was the top hole that was far out of line. I converted the round hole to a slot (as long as I could file into the hole). While not perfect alignment, it seems to help considerably. That took a lot of stess off the Tupperware, and -- so far -- the panel is holding find, grommet and all.
    J Goertz
    BMW MOAL
    2015 BMW R1200RT
    2012 Triumph Bonneville SE
  1. How to get better Tupperware alignment
    By flhfxd in forum Oilheads
    Last Post: 07-13-2019, 08:43 PM
  2. Under the Tupperware
    By CEXPilot in forum Oilheads
    Last Post: 03-17-2011, 02:38 AM
  3. Stripped Tupperware Nut
    By happy wanderer in forum Oilheads
    Last Post: 06-14-2010, 03:09 PM
  4. RT tupperware secrets??
    By 26667 in forum Oilheads
    Last Post: 11-27-2009, 09:22 PM
  5. R-12s Tupperware/Fairing
    By JK in forum Hexheads/Camheads
    Last Post: 10-10-2009, 02:36 PM
