Results 1 to 4 of 4
Thread: GS noise
    Dec 2007
    Indiana
    GS noise
    Have seen several comments regarding "noise" from these F/GS's when, particularly at lower speeds, running on irregular surface roads. It doesn't take much speed or uneven road surface to get some type of "something must be loose" noise from my 750. My chain is properly adjusted, clean and oiled.
    F850GS
    MOA #46783
    Apr 2006
    Nibley, UT USA
    For sure try going for a ride with cases removedóthey make noise on every bike Iíve owned except my latest one. I had no extraneous noise issues with the F800GS I rented in the Balkans, and it was equipped with only a Givi topcase. Hope you get the noise pinned down, those odd sounds can be irritating at times.
    Best,
    DeVern
    DGerber
    1983 R80ST ó 1984 R80 G/S-PD ó 2004 K1200GT w/Hannigan S/C ó 2010 K1300GT ó 2018 R1200GS
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    I always had good luck with a rubber mallet banging on the tires and frame of cars and bikes looking for rattles. I think that's why they used to kick the tires to listen for rattles. Good luck.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    Jun 2019
    Buena Vista CO & Marco Island FL
    I have the same issue with my 750, with less than 1000 miles on it. My first thought was the center stand or the side stand, but I donít think thatís it. Itís the same with or without the cases on. Iím going to try the rubber mallet idea but other than that Iím stumped on trying to diagnose this.
  1. New Noise 04 rt
    By wz31857 in forum Oilheads
    Last Post: 07-13-2012, 12:29 AM
  2. Engine Noise/Clutch noise '07 RT
    By TPBR1200RT in forum Hexheads/Camheads
    Last Post: 08-07-2010, 07:52 PM
  3. Wind Noise, I hate wind noise!
    By oldhway in forum Oilheads
    Last Post: 06-09-2007, 09:54 PM
  4. Noise.
    By Visian in forum Campfire
    Last Post: 05-24-2005, 02:33 AM
  5. Air-noise
    By MAGWA in forum Airheads
    Last Post: 03-30-2005, 01:57 PM
