Results 1 to 3 of 3
Thread: Starting gremlins
    The Blue Max 31310's Avatar
    Calgary Alberta
    Starting gremlins
    Have been experiencing minor electrical glitches last week. Other morning, rolled down driveway, turned on key, neither instrument cluster or lights came on. Turned it off, rocked in gear, back to neutral, it started but within a block, red warning light came on, turned around and took car to work. When starting, sometimes clicks at solenoid, then it starts. Battery is year old agm, connections all tight and clean, voltage at rest 12.5, down to 10 or so on starting, charges up to 14.5 running. Before tearing into it, relay or starter? Btw, mileage is 165K kms, this is a new wrinkle with an otherwise reliable bike. Oh, tank is full too.
    2007 R1200RT
    Jun 2007
    Portsmouth, NH
    AGM batteries are somewhat notorious for developing internal failures. Apparently the wiring between the cells cracks and causes failures that sound a lot like your problems.
    Calgary Alberta
    Thanks for replying, it was a battery gremlin. Back on the road again.
    2007 R1200RT
  1. Gremlins in my dash
    By priceranch in forum Motorrad
    Last Post: 04-24-2018, 12:28 AM
  2. ABS gremlins?
    By BMUUsed in forum Oilheads
    Last Post: 10-23-2012, 09:57 PM
  3. Electrical Gremlins!
    By mgalie in forum Flying Brick K-bikes
    Last Post: 05-16-2009, 02:45 PM
  4. gremlins in a /5
    By chwood4 in forum Airheads
    Last Post: 08-15-2007, 01:25 PM
  5. ABS Gremlins?
    By 120116 in forum Oilheads
    Last Post: 08-08-2007, 02:37 AM
