Results 1 to 10 of 10
Thread: 1985 K100 sudden loss of acceleration and super rich mixture smell from exhaust.
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    The bike runs nice, not great.
    History: old girl, about 80K miles, routine tune-ups, valves just checked, new plugs, one fuel pump/filter a few months ago.
    Up until lately, no complaints but suddenly got lazy and the exhaust smells super rich.
    Air filter is great, plugs look good, TB sync perfect, idles steady at 1000 RPM.
    My next thought is the timing changed and I have gone retarded a bit. Checked my marks with a strobe, marks align.
    Not sure where to go next except advance the timing and risk burning pistons/valves.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Yoda,
    Try this next. https://forums.bmwmoa.org/showthread...erature-sensor
    Don't advance the spark. That is not the problem.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    I read the original post and my mind instantly suspected the engine temperature sensor. But I see Lee beat me to it.
    Mar 2013
    You guys are on to something. The sensor is working but seems lazy or the thermostat is stuck open.
    The engine isn't getting very hot, about 150 degrees but I am not sure the reason is the thermostat yet. Pretty low ambients here last few days.
    I am a little afraid to bring it up to temperature in my shop without a fan cooling the exhaust but I guess if I remove anything that could melt, I should be OK?
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Lazy?
    Either the sensor exactly matches the water temp throughout the range or it doesn't. If it doesn't, it needs to be replaced. Use your infared temp gun to verify the water temp in the pan for different resistance readings.
    Usually you should remove the sensor and "bench test" it in a pan of varying temp water.
    If the sensor tests ok, clean the connections at the sensor and at the ECU with DeOxit. Any corrosion at the connections will vary the resistance seen by the ECU which will result in incorrect mixture.
    Mine, Hers, Spare
    Mar 2013
    Still could be the sensor but the thermostat is definitely not holding. Never gets hotter than 150F.
    Ordered a new thermostat, 4 weeks away!
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    In stock at EME: https://www.euromotoelectrics.com/pr...mostat-716.htm
    Don't forget to order the cover O-ring (under options) for $4.
    Mine, Hers, Spare
    Mar 2013
    Fixed-Thermostat
    I really wanted to post a picture of the thermostat but I think it wound up in neverland.
    Essentially, the thermostat fell apart.
    After we got it together, the engine started building and shedding heat. A quick, ginger run around the block and the change was noticeable.
    Rode it like I stole it, fan came on, builds nice response and the rich smell as disappeared.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mine, Hers, Spare
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    A ginger run around the block... that was your passenger?
    Interesting coincidence - my neighbor's Kia SUV was having temperature issues, so we got into the thermostat... not quite broken all the way through, but it was about to become two or three pieces.
  1. sudden loss of mileage
    By jagarra in forum Oilheads
    Last Post: 09-21-2018, 02:53 AM
  2. Fuel smell after hard acceleration 2014 R1200RT
    By fletchdude in forum Wetheads
    Last Post: 01-20-2018, 04:56 PM
  3. Sudden loss of compression
    By Omega Man in forum Best of the Forum
    Last Post: 06-10-2017, 11:15 AM
  4. Rich vs Lean (Mixture Adjusting)
    By papafoxtrot in forum Hexheads/Camheads
    Last Post: 12-16-2007, 01:11 PM
  5. R900/6 Rich Mixture
    By PhilScrivano in forum Airheads
    Last Post: 12-30-2005, 06:01 AM
