Results 1 to 14 of 14
Thread: K1300S Cruise Control
    Hi, Newbie here with a question.
    I have a 2016 R1200RS that has BMW cruise control. Im in the process of purchasing a 2013 K1300S, and Im wondering about the cost and difficulty in adding this cruise control to the K1300S? Is this even in the realm of a DIY project?
    Negative. Best feasible option is a Kaoko or Throttlemeister bar end. Obviously nowhere near true cruise control, but they work well enough to rest your hand on long trips.
    Quote Originally Posted by nh13s View Post
    Or Bob's Wrist Rest from Bob's BMW
    Rats!
    But, thanks for the input. The bike comes with Throttlemeisters. It’s nothing to break one’s crayons over, but for real cruise control is nice.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    The ezCruise is inexpensive, easy to install/use and effective.
    https://www.amazon.com/CherryPic-Jun...NsaWNrPXRydWU=
    Kevin Huddy
    Downhill a little faster. Uphill a little slower. Refreshing honesty there.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by zoomie View Post
    Check with Jerry at Pirates Lair. He used to sell a aftermarket electronic cruise control. I think he dropped it from his site because of the cost.
    He may be able to special order one for you.
    http://pirateslair.net/ProductS.htm
    http://pirateslair.net/MVContact.htm
    Lee
    2016 R1200RS
    MOA # 30878
    Dec 2007
    San Juan Island, WA
    Accessory power plug out!
    I have a 2015 K1300S with the stock accessory power plug on the left side near the shift assist. It used to have power. It no longer has power. These new bikes do not have fuses. I've tried re energizing by turning ignition switch on and off but to no avail. Can this be diagnosed with a Can Bus unit? Does a dealer/service shop have to fix it? Any ideas are appreciated!
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by Rangeron View Post
    First step would be to access the back side of the power plug and verify that there is/is not power present on the wire. The BMW power sockets have metal pins embedded in plastic on the back side, and use of higher current draw loads (like pumps), or poor connectivity with the inserted power plug, can heat things up enough to allow the pins to disconnect from the socket, thereby prevent power from being accessible when plugging a device into the socket.
    If you verify that no power is being energized to the wires feeding the socket *then* it will be time to look into CanBus diagnostics.
    Best,
    DeVern
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    It's been done in the past so there is hope at least. A couple of links to point you on the right direction. Good luck!
    http://pirateslair.net/CruiseK1200S.htm
    https://youtu.be/JM0iXSYOBgg
    https://www.murphskits.com/product_i...roducts_id=369
    Neal - '16 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Registered User twistedthrottle's Avatar
    Dec 2004
    Exeter, RI (Route 3)
    Kaoko
    The Kaoko is definitely an option for this bike. If you want to see how it works, watch here...
    Also, check this page for more description and information on the one for BMWs like yours --> Kaoko Throttle Lock for Select BMWs
    Get in touch with us if you have questions!
    The Twisted Team
    TwistedThrottle.com: the official North American distributor of
    SW-MOTECH, DENALI, R&G, Barkbusters, DrySpec, MRA, Kaoko and more!
    Call us at 855-255-5550
    Left Coast Rider
    Nov 2011
    Jul 2017
    Aiken, SC
    I disagree, it IS possible, but a pain. Some of the r1100S group have added it to their bikes, which it was never offered. The K1200 should be possible, since other K1200 had it offered. From my research you'll need a K1200 cruise module so there is a CAN bus connection.
    http://forums.pelicanparts.com/bmw-r...ol-r1100s.html
    May 2003
    SW Iowa
    Quote Originally Posted by n41ef View Post
    The K1200 Brick is completely different than the K1300S and K1200S.
    Lee
    2016 R1200RS
    MOA # 30878
  1. cruise control
    By marklutz in forum F-Twins
    Last Post: 09-19-2016, 05:11 PM
  2. Replies: 8
    Last Post: 05-18-2016, 12:40 PM
  3. BMW Cruise Control
    By prwff8 in forum Oilheads
    Last Post: 05-13-2011, 03:35 PM
  4. When did the RT get cruise control?
    By jcbappliance in forum Oilheads
    Last Post: 10-09-2010, 11:59 PM
  5. Vista Cruise Cruise Control for the Real F650
    By KPINVT in forum Thumpers - F & G bikes
    Last Post: 06-28-2010, 09:35 PM
