Results 1 to 5 of 5
Thread: 1988 K75C White 205k Alternator damper cup nut torque spec
    PeteG
    Dec 2009
    Woodacre, California
    Hello,
    Removed my dead alternator fan and damper cup. Nut came off with impact wrench. Damper cup and fan were pleasantly easy to remove. Now it is time to install them on the refurbished one.
    Clymer's doesn't have a torque value for the nut (shown). I'm not finding it on a search here or in Tech. I found this spec on the web (shown). Does 37 ft lbs. sound correct to those that have gone down this path before me?
    Thanks in advance,
    Pete
    K75 alternator nut.jpgAttachment 75171
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    BMW factory spec. (From BMW factory repair manual) is 45nm +/- 6.
    That converts to 33 ft/lb +/- 4.
    37 ft/lb would work fine.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    PeteG
    Dec 2009
    Thank you Lee!
    Pete
    Jun 2009
    Rochester, MN
    Just an FYI for that torque chart - the upper and lower fork pinch bolt recommendations are reversed. Everything else worked great as a reference (and was comparable to my Haynes when possible) through my K75 wrenching/ownership.
    PeteG
    Dec 2009
    Quote Originally Posted by drneo66 View Post
    Great catch dreno66,Attachment 75190
    I've edited the spec chart, deleted the prior post, and have posted it again with the correction. It now agrees with my Clymer as well.
    Pete
  1. Torque spec
    By hfm4 in forum Oilheads
    Last Post: 08-30-2012, 02:05 AM
  2. torque spec disc to wheel
    By 129974 in forum Airheads
    Last Post: 12-31-2010, 07:34 PM
  3. torque spec
    By ckp543 in forum Airheads
    Last Post: 01-27-2010, 04:22 AM
  4. Torque Spec needed
    By briana in forum Hexheads/Camheads
    Last Post: 10-13-2009, 12:32 AM
  5. k75 (1995) - Alternator spec.s ??
    By walterdaniel in forum Flying Brick K-bikes
    Last Post: 11-14-2005, 03:00 AM
