Results 1 to 9 of 9
Thread: Cannot see through sight glass anymore
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    I cannot see the oil level through my sight glass anymore.
    Cleaning the outside doesn't solve the problem. There seem to be a deposit of some sort on the inside of the glass.
    Any idea on what can cause this?
    Is there anyway to clean it?
    According to the RSD DVD it takes a whole bunch of specialized tools if you want to replace it.
    I use Motul 7100 10w60 synth oil and oil changes are always done following the maintenance schedule. (I just did it today)
    The bike is an R1200Rt 2007 and has 178436 km
    I'm not overly concerned, it's just annoying. I put 4L in when I change the oil and 500ml when the (!) sign come on.
    BTW Motul 10W60 oil is red
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    It is age related and you should think about replacing it with your next oil change. The plastic window is getting brittle too and doesn't take much work to remove it.
    Just don't forget remove the metal clip and using two wood screws it'll pull right out. There are some vids on youtube somewhere for this procedure. YMMV
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, 17 R1200RT
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by RIDERR1150GSADV View Post
    I've been searching through YouTube but didn't find any clear video on the procedure.
    I have the RSD DVD and the BMW procedure uses a lot of specific tools.
    I'm no mechanic but if I could find a clear step by step procedure I would do it. (I was able to replace the clutch myself this way)
    Daniel
    Mansfield,MA
    When you get a chance, look through the threads at the bottom of the page.
    There has been lots of information on sight glass replacement.
    Mod Squad
    2009 F800GS 1994 TW200
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    If it's plastic I like Paul Glave's tip of using a solder iron to make a hole instead of drilling.
    Lee
    2016 R1200RS
    MOA # 30878
    Jun 2009
    Rochester, MN
    Quote Originally Posted by Dann View Post
    Try this:
    https://www.youtube.com/watch?v=B4Mj2R8KGgw
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    Dan, a friend of mine cracked his replacement sight glass while tapping it in. He's normally a fairly competent mechanic and said it would have been cheaper to have the dealer do it. He had his bike transported to the dealer.
    Pat
    Ride Safe!
    '16 RT
    Liaison 20774's Avatar
    I used the Tag Cloud and found the following links to sight glass replacement...it's for Oilheads, but I suspect a lot of it crosses over:
    https://forums.bmwmoa.org/tags.php?t...eplacement%2C+
    Apr 2017
    S.Florida
    The procedure is identical to the oil-head. The difference is the retaining ring that keeps the sight-glass assembly in the engine block. No real mystery here.
    https://www.youtube.com/watch?v=VVcwkB9qFcI
    MOA # 108516
  1. sight glass '98 RT
    By bp@sr9 in forum Oilheads
    Last Post: 04-01-2018, 06:55 PM
  2. K75 oil sight glass
    By roncooper in forum Flying Brick K-bikes
    Last Post: 10-14-2012, 02:03 AM
  3. oil sight glass
    By 31310 in forum Hexheads/Camheads
    Last Post: 05-17-2010, 04:31 PM
  4. oil sight glass
    By rado360 in forum Oilheads
    Last Post: 09-29-2008, 11:17 PM
  5. More sight glass
    By TIGINBNA in forum Oilheads
    Last Post: 02-24-2007, 04:40 PM
