Results 16 to 21 of 21
Thread: R100R won't crank good battery
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Fuse
    If you replaced the blown fuse with another and it too blows, you have a short in the system somewhere.
    A blown fuse can also mean an overload or draw of current in a system.
    Have you found a wiring diagram for the bike?
    Short circuits can happen in a lot of places. Over draw of current in a starter system can be one of two things, a poor connection or dirty connection in the system or a bad starter.
    I don't remember much from my early days as a mechanic but I remember in some cases a bad battery when the starter is cranked, will cause a spike in amperage and drop in voltage.
    A load test of the battery is the only proper way to test it. It can have 12 volts while sitting with no load, When a load is put on it, it can drop too as much as 2 volts depending on how many cells are still good. St.
    Registered User Guenther's Avatar
    Colorado Springs, CO
    murty, it seems you expect others to have a spiritual connection with your bike...I don't have that!
    One was blown
    It would definitely help to know which one blew by the numbers I gave in an earlier reply.
    So all four circuits protected by fuses work (according to the tests I gave in my earlier reply)?
    With ignition on, is the low beam on?
    /Guenther
    2017 F700GS
    Number 3 fuse
    Quote Originally Posted by Guenther View Post
    /Guenther
    Hello Guenther, counting from left to right it was number 3 that was blown.
    Best,
    Murty
    With ignition on...
    /Guenther
    With ignition on there are no lights, no dash indicator lights, horn, turn signals don't work.
    Problem solved
    I had the battery load tested, it failed and I replaced it with a new one - problem solved. Thanks for all the helpful advice!
    Mansfield,MA
    Quote Originally Posted by murty View Post
    Great
    Letting us all know by finishing a thread really helps.
    Mod Squad
    2009 F800GS 1994 TW200
  1. 1992 r100r battery advice
    By tinkerer in forum Airheads
    Last Post: 03-09-2019, 06:04 PM
  2. Crank, crank, crank, no start
    By 14gsused in forum Wetheads
    Last Post: 10-23-2018, 09:28 PM
  3. Good starter, Good battery, Good selonid, won't turn over
    By chuck_donahue in forum Flying Brick K-bikes
    Last Post: 07-02-2009, 06:32 PM
