When I went to start my 1994 R100R that has not run in a month or so and has been on a battery tender the entire time, I turned the key on and the indicator lights all came on as normal but when I pressed the start button the starter motor engaged for a fraction of a second then everything went dead.
- None of the dashboard indicator lights illuminate when the key is turned on.
- Battery connections are clean and tight.
- I put it back on the battery tender and it is flashing green indicating ok.
- Also with the ignition on sometimes the tach needle with rise and fall slightly.
- And with the ignition on and kill switch moved from run to off, the bike makes a faint buzzing noise from the general vicinity of the battery.
- Prior to this episode the bike has been starting and running great.
Any troubleshooting suggestions are welcome.
Thanks in advance.
