Results 1 to 15 of 21
Thread: R100R won't crank good battery
    When I went to start my 1994 R100R that has not run in a month or so and has been on a battery tender the entire time, I turned the key on and the indicator lights all came on as normal but when I pressed the start button the starter motor engaged for a fraction of a second then everything went dead.
    [LIST][*]None of the dashboard indicator lights illuminate when the key is turned on.[*]Battery connections are clean and tight.[*]I put it back on the battery tender and it is flashing green indicating ok.[*]Also with the ignition on sometimes the tach needle with rise and fall slightly.[*]And with the ignition on and kill switch moved from run to off, the bike makes a faint buzzing noise from the general vicinity of the battery.[*]Prior to this episode the bike has been starting and running great.
    Any troubleshooting suggestions are welcome.
    Thanks in advance.
    Albuquerque, NM
    Doesnít really make much difference if tender was attached if the battery is old enough to be at the end of its life.
    Itís almost always the battery. The only other likely thing is the starter relay.
    Hereís how my recently failed battery acted ... could start the bike no problem. Could turn motor off and try to restart ... nothing. Just one example. They usually go quick, no warning.
    Kent Christensen
    21482
    Jerryb811
    Aug 2012
    Kennesaw, Ga
    Agree on the battery. In 30 years of being a service advisor when I heard your description the battery was bad probably 95% if the time. I'm personally sold on the Odyssey agm batteries-have had great experience with them & have Odysseys on both of my airheads (one is a '94 R100RT).
    1985 R65, 1994 R100RT Gone and missed:BMW: 68 R60, 71 R75/5, 72 R60/5, 75 R90/6. Yamaha 350. Kawasaki S2 (2), H1, Z1, KZ1100. Norton 750 Commando. Not missed: Honda 305 Dream, Suzuki 250.
    Liaison 20774's Avatar
    I would first look at the starter relay. If the terminals have some corrosion, the starter solenoid might not get power.
    Aug 2005
    Deerfield, Ohio
    Summer heat must be really hard on batteries. I've had two instances lately. Different days, when a friend had ridden the bike then shut it down. And the bike would not restart. No lights, nothing. Neither battery would take a charge. In both cases a new battery fixed the problem. The interesting thing for me is that there was absolutely no warning in either case.
    1980 R100T
    1971 R50/5
    G650GS
    1967 R60/2, 1947 James ML
    Quote Originally Posted by daz View Post
    That is typical of today's fragile AGM batteries.
    Registered User Guenther's Avatar
    Jan 2007
    Colorado Springs, CO
    Slight chance that the ground wire is loose at the transmission point.
    /Guenther
    2017 F700GS
    Mar 2010
    Vancouver, B.C. Canada
    Whenever I get a click but no go situation and I am fairly certain it should be in a fully charged state the very first thing I do is load test the battery. It doesn't matter what the volt meter tells me in the event that I check voltage first. If it is over 12V great but that only means it _might_ be OK. If I load test it and the voltage drops below 10V the battery needs to be replaced.
    If the battery tests OK then I start with pulling the starter relay and cleaning the terminals along with tightening them up with a gentle squeeze of the pliers on the female spade connectors to insure a good fit.
    If that is all OK I remove the starter cover and check the voltage on the black wire to the solenoid while pressing the starter button. If there is 12V there you may have a solenoid connection issue, solenoid issue or starter motor issue assuming the connection is good.
    Make sure the heavy gauge starter cable and your ground cable have good connections as well. Do all these things before you start swapping expensive parts.
    Jul 2004
    Charlottesville, VA
    Quote Originally Posted by murty View Post
    ... but when I pressed the start button the starter motor engaged for a fraction of a second then everything went dead.
    To me, that says either loose battery connections (which you say are fine) or a bad Valeo starter.
    Anton Largiader 72724
    Tech articles - YouTube
    Update
    Thanks for all the helpful advice - much appreciated! I just got the bike back home where I can work on it. The battery voltage is 12.78v. When I turn the ignition key to ON none of the dash indicator lights illuminate. Also nothing else works - horn, signals etc.
    I read somewhere that there is a relay that switches power to the entire electrical system - is that true? Where is it located? Any other troubleshooting advice?
    Thanks,
    Paul
    Jan 2007
    There is not a power-all-on relay. But there's the small starter relay under the tank. It turns off the headlight when you push the starter button. But this relay would not power off the dash lights nor the horn when you push the starter button.
    Did you check the three - and only -fuses?
    /Guenther
    2017 F700GS
    Feb 2005
    Trinity, NC
    I would check that starter relay, and the wires going to and from it. Even though the relay doesn't control those other electrics, I believe the main power wire goes to the starter relay and then branches back to the rest of the bike. Known problem that sometimes the main power wire gets separated at the relay.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    rabid reader dbrick's Avatar
    Santa Cruz CA
    The symptoms continue to be those of a bad connection. How did you ascertain the battery connections are "clean and tight?" Just looking isn't enough.
    The only way to know that the connections are good is to remove all the connections, at both ends of every wire or cable connected to the battery and the starter. Clean the connectors and their posts. Reassemble.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Jan 2007
    I was talking about the small relay which sits under the tank together with the other relays. It gets its power straight from the battery and is not fused(!) and always hot. It only prevents you from starting the motor when neither in neutral nor the clutch pulled.
    The relay/solenoid attached to the starter gets its power straight from the battery via the thick red wire.
    All other electrics get their power from the ignition switch passing through either of 4(!) fuses. Easy to check without even looking at the fuses.
    With ignition on...
    - does the break light come on? (fuse #1)
    - is the tail light on? (fuse #2)
    - does the clock work or do you measure ~12 volts at the accessory socket? (fuse #3)
    - does the horn work? (fuse #4)
    If none works then have the battery tested at an auto parts store.
    If the battery is ok then it might be problem with the ignition switch.
    /Guenther
    2017 F700GS
    Quote Originally Posted by Guenther View Post
    /Guenther
    Yes, this bike has four fuses. One was blown, and I replaced it but the condition is unchanged.
  1. 1992 r100r battery advice
    By tinkerer in forum Airheads
    Last Post: 03-09-2019, 06:04 PM
  2. Crank, crank, crank, no start
    By 14gsused in forum Wetheads
    Last Post: 10-23-2018, 09:28 PM
  3. Good starter, Good battery, Good selonid, won't turn over
    By chuck_donahue in forum Flying Brick K-bikes
    Last Post: 07-02-2009, 06:32 PM
