Results 1 to 7 of 7
Thread: Attaching a Cozy Rocket sidecar to an '01 R1100RL
    The problem is the bike has an upper frame but no frame underneath. I have been told I need a subframe. I think it would be easier to find a needle in a haystack. I have been all over the internet. The service manager at my cycle shop has talked to several other shops without any luck either. I am ready to send the sidecar back. If anyone has some knowledge as to how this can be accomplished, please let me know.Thank you, Dennis Keenan. Maywood, NJ MOA #148168
    Mansfield,MA
    Welcome to the forum!
    If you don't get any responses to your question that help, I'll move this to the Sidecar and Trikes part of the forum.
    Good luck.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Aug 2018
    Fargo, ND
    I would imagine that a commercially made subframe doesn't exist, or be extremely rare which you have found out. Time for someone with knowledge to fabricate one. Also all the plastic will be a problem. It may have to be removed to fit a sidecar.
    Have you tried,
    DMC sidecars
    866-638-1793
    www.dmcsidecars.com
    From the only real Fargo, ND!
    Sep 2006
    CENTEX USA
    The Roadster 1100 is close to the GS which has a lot of sidecar users. As mentioned DMC would be a great source to check out. Pretty sure you will need to get bike to them to fabricate the subframe and set up the car.
    One suggestion before you hang a sidecar is to service the transmission input shaft splines. I have removed and replaced two different 11GS sidecars and sub frames replacing trans seals and doing a spline lube...it's a PITA once the subframe and car are in place.
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    Check with Claud Stanley Motors (CSM), or DMC. Your '01 R1100RL isn't that unusual and they've mounted bunches of subframes on similar bikes. Don't give it up yet. Good luck.
    http://freedomsidecars.com/
    Gary Phillips - #6322
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '00 R1100RS
    Thank you. Claude has told me that he is just home from the hospital and his shop is swamped with work. He also redirected me to DMC.
    Quote Originally Posted by PoorUB View Post
    Have you tried,
    DMC sidecars
    866-638-1793
    www.dmcsidecars.com
    " I am in contact with DMC. Thank you. "
  1. Who has a 2001 BMW R1100RL
    By mattmiller in forum Oilheads
    Last Post: 07-23-2015, 05:58 PM
  2. Need help w/cozy and 78'R100/7.
    By dogstar in forum Sidecars and Trikes
    Last Post: 06-10-2013, 03:55 PM
  3. R1100R vs R1100RL
    By enjine in forum Oilheads
    Last Post: 08-07-2008, 12:55 PM
  4. what is the service schedule for my r1100rl?
    By mrbreeze in forum Oilheads
    Last Post: 10-10-2007, 02:19 PM
  5. Replies: 14
    Last Post: 06-10-2005, 03:52 AM
