Results 1 to 9 of 9
Thread: Code reader , abs light on
    Nov 2015
    Potten Quebec Canada
    Hi
    I am interested in buying a code reader looking for best one for a 2007 R1200RT ?
    Abs light on , but wouldnít mind if it worked other vehicles GM Honda etc
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    AFAIK the only on that works is the Hexcode GS-911
    Not cheap but does a lot more than just read fault codes.
    It will not work on other vehicles than BMW bikes
    https://www.hexcode.co.za/
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2019 R1250RT - 2007 R1200RT (186,000 km) - IBA # 56396
    If you have an android phone you can use the Motoscan app with an ELM 327 OBD II Bluetooth reader and the appropriate 10-pin interface cable to hook into your bike.
    Some info on Motoscan:
    https://www.google.com/amp/s/www.r12...p.html%3famp=1
    ScanTool OBDLink LX Bluetooth:... https://www.amazon.com/dp/B00H9S71LW...p_mob_ap_share
    I know this particular one works great; be careful because there are some cheap Chinese knockoffs that do not.
    OBD2 Diagnostic Cable for BMW... https://www.amazon.com/dp/B075K7MQFC...p_mob_ap_share
    Same remarks apply to the cable; this one worked with my BMW bikes.
    Cost for the hardware above is about $70; the app costs from $29-59USD Depending on which version of the app you get (Pro or Ultimate).
    I have a GS-911 Wifi version - and also use the Motoscan app with my android device. For most jobs on a Hexhead the Motoscan/OBD II solution works just fine, and I can use the scanner with some of my cars/trucks as well (with a different app like Torque).
    Iíve used the android solution I detailed above on a 2006,2007, 2008 and a 2009 R1200 RT... and itís a good option if you donít have $400 laying around to buy a GS-911.
    Will Motoscan do everything GS-911 does? No. Will it do most of the stuff we want to do like reset service counters, test displays and actuators and other service functions? Yes.
    Nov 2015
    Thank you ,
    Jun 2009
    Rochester, MN
    Don't forget that the GS911 can read an error code without consuming a VIN number, so you may want to ask around in your local club to see if you can borrow one to see what the code exactly is.
    Are you wondering why the ABS light is on? Does it come on solid when you turn key or crank bike? (ABS pump gone) Or....does it flash normally until you pull off and then come on solid? (ABS pump going, can get some extra life out of it by whacking the pump with a mallet)
    Sent from my iPhone using Tapatalk Pro
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
    Nov 2015
    Quote Originally Posted by brianhinton View Post
    Ok
    Have done that with electric window motors and they have worked for years after
    Will try it
    Itís going to the dealer for tires so will have them check it for codes
    Decided not to buy code reader for now
    Registered User Coma's Avatar
    May 2015
    Emerald Coast
    Blog Entries
    If it is the ABS pump then before you shell out the $2300 + labor check out http://modulemaster.com. They repaired mine for $250, with a 5 year warranty.
    There are some modes of fail they can not fix.
    2008 R1200GS
    Okay delmar, let us know how it goes
    Sent from my iPad using Tapatalk Pro
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
  1. Replies: 12
    Last Post: 08-24-2018, 11:59 PM
  2. Brake light wire code for Ď16 R1200RS
    By steen1 in forum Wetheads
    Last Post: 07-27-2018, 05:49 PM
  3. Replies: 5
    Last Post: 02-10-2018, 07:29 AM
  4. code reader gs911 available
    By manofsteel1 in forum Oilheads
    Last Post: 04-18-2016, 09:17 PM
  5. BMW Computer Code Reader
    By BMWK1200LTRIDER in forum Flying Brick K-bikes
    Last Post: 01-02-2007, 04:34 AM
