Page 22 of 23 FirstFirst ... 12 20 21 22 23 LastLast
Results 316 to 330 of 338
Thread: Post here if you've had prematurely worn cam lobe(s) in your wethead
  1. #316
    Quote Originally Posted by LFarling View Post
    So they are doing the rocker arms also. That is the issue as has been said but I still dont understand it.
    If a diamond coating fails as in comes off, hows does it become harder and cut the cams more then a diamond coating? I mean I used diamond coated drill bits to cut glass so understand the abrasive properties but do not understand the sliding or not wearing the cam lobe unless it fails.
    Not arguing, just trying to understand that concept.
    Not really sure to be honest. If they're replacing all eight rocker arms, it would seem that the rocker arms are too hard for the cam material. If they're replacing the cam because it's too soft, that might be a second quality issue that when it's combined with the first, causes engine problems.
  2. #317
    AZ
    I they are replacing all 8 rocker arms, shouldn't they also replace all 4 cams? It seems there is no way to know if further degrading of the coating would not occur in the future.
    MOA #107139
    RA #28511
  3. #318
    Quote Originally Posted by azgman View Post
    Not sure. My expertise is more with Harley motors than BMW's, this is my first one.
    That said, if cost was no object and I was the one calling the shots, the protocol to assure no second-order impacts in my mind would be to replace the rocker arms, replace the cams (all of them). replace the oil pump (it's been pumping metal), replace the oil and filter, drop and flush the sump, and do a full engine flush to get as much metal out of the oil paths and bearings as humanly possible. Inspect the piston sleeves for scoring. Install a magnetic oil plug.
    Then, treat it like a break-in service and change the oil and filter at 500-600 miles with a valve check, cam lobe inspection, and a solid eyeballing.
    But that's a perfect situation in my mind.
  4. #319
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    They have to be replaced as a set for each head.
    My Motorrad Blog
    My Motorrad YouTube
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
  5. #320
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by mikehsg View Post
    I've heard they only do the cams and followers. I have to wonder what the effects are of that crap going though the oiling system. It's like, lets do the bare minimum to get them beyond having to do anything more about it. IMO, I would say replace the engine.
    My Motorrad Blog
    My Motorrad YouTube
  6. #321
    Registered User cap's Avatar
    Oct 2016
    Fort Collins, CO
    The suggested fix from Bob's was all 8 rocker arms ....
    I think of those as "cam followers." And if they are replacing 8 cam followers, then they should also be replacing 4 camshafts.
    As an aside, at least one member of this forum posted earlier in this thread that they had cam lobe wear happen a second time after the initial repair.
    Cap
  7. #322
    Quote Originally Posted by ponch1 View Post
    I did tell the service writer if they'd give me full book for it I'd trade it right then. I have concerns for the longevity of the motor, TBH, but if the oil's clean and doesn't look like it had a stripper in the sump, may be OK. I mean, if the cam metal's crap then it's likely softer than the rest of the motor.
  8. #323
    What are the odds?
    Does anyone have any idea of how prevalent the problem is? How many failures out of how many engines manufactured? Are there any dealers on this site that could tell us/me how many bikes (with this engine) have the problem vs. how many they've serviced? I'm having my bike (2017 R1200RT) checked (20,000 miles) this week and I'm wondering about my odds.
  9. #324
    Quote Originally Posted by mxsx337 View Post
    Given there's been little effort in finding incidences and that the dealers seem to be quite familiar with it, the prevalence can't be that low. But, my gut tells me BMW considers the specifics to be proprietary as it's not a recall.
  10. #325
    Dec 2010
    Fountain Hills AZ
    I am sure BMW knows, but there's nothing to be gained by sharing that information. Heck, they are often reluctant to admit there are problems let alone the details of how many etc.
    My Motorrad Blog
    My Motorrad YouTube
  11. #326
    UPDATE: The awesome team at Bob's and BMW are making this one right. They're covering 100% of he repairs for me, and since it's dealer service, all parts and labor are warranted for 2 years.
    Waiting on parts for a couple/few weeks, but they're standing behind the bike. THIS is how you get loyal riders!
  12. #327
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    Good for you! A bright spot in this ongoing problem.
    A shame for all those who have had this issue, and those who are yet to experience it.
    Lee
    2017.5 R 1200 GSW
  13. #328
    Inspect, inspect, inspect!
  14. #329
    Oct 2016
    Harrisburg, PA
    I do every 6K.
    I check valves and cam timing and change FD fluid and oil and filter every 6K.
    It is all I can do to stay on top of it.
    Lee
    2017.5 R 1200 GSW
  15. #330
    I do every 6K.
    Once correctly set does the cam timing change???
  1. Post a picture of your Wethead
    By 20774 in forum Wetheads
    Last Post: 06-17-2021, 02:58 PM
  2. Not a fatality if wearing a helmet?
    By OfficerImpersonator in forum Gear
    Last Post: 01-28-2020, 12:21 AM
  3. Wethead GS Farkles - Post them here!
    By Emoto in forum Wetheads
    Last Post: 06-30-2015, 10:46 PM
  4. ABS-II Activating Prematurely
    By limecreek in forum Oilheads
    Last Post: 12-05-2012, 06:55 PM
  5. Your wearing your helmet when
    By mrich12000 in forum Campfire
    Last Post: 05-29-2007, 02:11 PM
