Results 1 to 15 of 23
Thread: What is the best used bike?
    May 2006
    San Francisco, CA
    How is that for a topic?
    No, the answer is (probably) not the bike you are trying to sell. What I'm looking for is the best bike for ME. But I haven't ridden enough different bikes and am looking for input from the forum on what would be good.
    So, what's going to make a good bike for me? First a little background: I've owned a K75T for over 30 years. During that time, I've put 100k miles on the bike. That's not a lot of miles per year, and I hope to ride more in the future. The bike has been great. Its never left me stranded, has decent wind protection, good enough handling and a smooth ride. So, why get rid of it? Well, it's been totaled 3 times (long story), the seat needs new foam, several pieces of body work need replacement and the seals/gaskets are starting to go (can you believe the gaskets have lasted only 32 years?!). And a new clutch is probably around the corner. I could fix all this. It would be several thousand dollars, and I'd be left with a bike with 1987 technology, performance, etc.
    I may be wrong, but I think I can do better....
    So, what's going to be 'better'?
    Well, what I do on the bike is mostly commuting in the SF Bay area. So something where the max width is the handlebars is needed to make lane splitting easy. I do take it on trips, so removable hard luggage and a comfortable riding position would be great, along with a way to strap on a tent and sleeping bag. I park it in a garage in between my neighbors cars, so the ~87 inch length of the K75 must not be exceeded by more than a couple of inches. While I've taken the K75 to the track (Thunder Hill is FUN), I'm not going to be the fastest guy on the track, so don't need to pretend I am and racer performance is not relevant. I don't go off road.
    Budget? 7-9k? Am I delusional in thinking I can pick up a bike meeting the above that was build in the 2010's for this price? If so, please tell me. I won't be offended. But a quick check on eBay says that I might be OK.
    What I'm looking for from the forum is something like "you should check out the BMW model XYZ. But watch out for the 20XX model year(s) because the drive lines fails/is known for surging/some other problem I would have never known about unless I asked."
    Ultimately, I'm at the beginning of my purchase process and am looking for thoughts on what might be good for me, rather than a specific bike for sale.
    TIA for your thoughts!
    Easy peasy. Simple as simple can be. K75S
    If you want a bit more modern then F800s
    Want newer yet then R9T set up as an urban warrior bike
    Jul 2008
    Central PA
    An Oilhead without the servo-assist (whizzy) brakes should cost around 2~3K and be nearly bullet proof. Almost as bullet proof as a K75.
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
    1) My expectations are never low enough & 2) Incompetence is infinite ........David Brooks
    Apr 2016
    Seattle
    An F800ST or the later F800GT would be in your budget and do what you are looking for. I commute in the Seattle area year around and take it on multi-state trips. With some bar risers and lowered foot pegs, the ergos become nicely relaxed.
    Chris
    Elnathan - 2014 BMW F800GT
    IBA# 49894 True Rounder = 0-20's - Rounder -- to -- 100's+ Red Hot Rounder
    John 14:6
    sMiling Voni's Avatar
    You might also consider a brand new BMW. Like either the G310R or G310GS, out the door for less than the $7,000 you are thinking about spending. ABS is a huge improvement over the K you've been riding.
    Voni
    sMiling
    BMW MOA Ambassador Emeritus / FOM / Roving Forum Moderator/
    Selected Friends of Wile E Coyote/ A Million 100 thousand BMW sMiles
    v
    Sep 2012
    Lansing, Kansas
    If it has to be a BMW . . . then I agree with Paul and Voni. Especially as regards the F800 (my current bike) or the G310 (my likely next bike).
    If you are open to another brand, then I recommend you go with either a Honda or Yamaha (most reliable bikes made), choose some model comparable to the BMW 800 or 310.
    Good luck.
    Royce
    On the coast of Kansas
    2012 F800ST
    May 2006
    San Francisco, CA
    Thanks Paul. But I'm not sure I understand what you are trying to say. First: are you saying K75's in general or specifically a K75S(I always thought the red one was the most beautiful bike BMW made!)? i.e. why would the 'S' be different than the rest of the K75 line?
    Second: The assumption I have in my question is that a 'modern' bike will give me better performance/safety/reliability with less maintenance (old gaskets/hoses/wear and tear). By specifically calling out a bike that hasn't been build in the last 20+ years, are you suggesting I'm making the wrong tradeoff or perhaps I'm making the wrong assumption?
    May 2006
    San Francisco, CA
    Quote Originally Posted by royce View Post
    thanks royce. Yes, I'm trying to keep it to BMW. Not 100% sure why. Perhaps I need to discuss that with a therapist...
    May 2006
    San Francisco, CA
    Quote Originally Posted by Voni View Post
    Voni
    sMiling
    Thanks Voni! That's one hell of a review!
    Quote Originally Posted by 48882 View Post
    I had a 1986 K75T. I rode it 369,643 miles in 19 years, before it was totalled in an accident. At that moment I was 7 days and 40 states into a 49 state ride. The notion that these bikes somehow rot with age is wrong. Change brake lines to Speigler once, replace a seal occasionally maybe, fuel hose maybe, etc. That bike never had the head off, never had any transmission work. Basically routine maintenance, brake pads, a driveshaft or two.
    I specifically said K75S model because you wanted something with narrow bars. Ditto why I said F800S. I agree with the post that an R1100R or RS would be OK but was really thinking lighter and smaller than that.
    Rally Rat 1074's Avatar
    Sep 2004
    Las Vegas, NV
    K75
    I agree with Paul but would throw in the K75C model as well. i know of one owner with, at the time, over 450k miles with only routine service and a timing chain! Not that I'm prejudice but my current "newest" bike is a 1987 K75C. It does everything I need it to do and doesn't shed a lot of heat on my thighs as some models do.
    Plus, the price for a good used one is well within or below what you want to pay!
    Boxerbruce
    May 2006
    San Francisco, CA
    Thanks Paul and BoxerBruce.
    You are making an excellent argument for me to spend the $$ on my K75T!
    In my post #12 I failed to mention that I still have a couple of K75s. A K75RTP former police bike and a '94 low seat standard. The cop bike has about 50K on it and the standard has right at 125K. It will get a new clutch this fall.
  1. Replies: 3
    Last Post: 02-26-2017, 01:30 PM
  2. Replies: 5
    Last Post: 12-22-2015, 01:01 PM
  3. 2012 GTL - Bike to Bike Comm, Retaining Bluetooth ?
    By ericmsimon in forum Straight 6 K1600 GT/GTL/B
    Last Post: 11-25-2012, 04:37 PM
  4. Art of the Bike Vintage Bike and Blues Festival
    By nplenzick in forum Regional Northeast
    Last Post: 06-12-2012, 02:11 AM
  5. Bike to bike full face helmet
    By miairhead in forum Gear
    Last Post: 06-22-2010, 06:50 PM
