Results 1 to 15 of 20
Thread: Valve adjustment intervals on (cam head?) 2012 R1200GSA
    Do I have this right -
    On a 2012 gsa the valve check/adjustment intervals are at the first 6,000 miles initially and then every 12,000 miles thereafter?
    OLD BULL
    Sep 2007
    Kingsley, Mi
    Yep
    Yep
    Thank you sir.
    Nov 2017
    Collierville, TN
    The checklist from ASCycles and my REPROM says valve clearance check every 6k miles.
    My BMW mechanic does the valve check every 12K on my camhead, checked twice now, they have not been out of spec
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    Krmugin
    Apr 2014
    West Coast
    The factory reccomended interval is 6,000 miles...
    The factory specification for camhead valve checks is every 10,000 kilometers. We translate that to every 6,000 miles.
    Of course, you can check them whenever you please... It is true that they seldom require adjustment. I don't think that I've adjusted mine in over 20,000 miles, though I probably will have one valve out of spec at my next check.
    My apologies for not posting the form, but I was not able to do so.
    You can go to A&S BMW and download the maintenance forms for free. There are several (6,000 with annual, 6,000, 12,000 with annual, etc.), and probably that is the source of the confusion for you. The 12,000 mile lists a valve check, but so does the 6,000.
    Nov 2017
    Collierville, TN
    Here are the forms: I fill one out every time I do the maintenance to document that I did it and what, if any, findings I have.
    R1200RT-DOHC 6K Service.pdf
    R1200RT-DOHC 6K with Annual.pdf
    R1200RT-DOHC 12K Service.pdf
    R1200RT-DOHC 12K with Annual.pdf
    My mechanic just did an 18K service on my 2012gsa and said the valves are only checked every 12K, so not at the 18K service (will be done at 24K).
    I read somewhere that when the camheads came out BMW initially said to check valves every 12K (after the first check at 6K), then amended that to recommending they be checked every 6K.
    Wondering what BMW actually recommends, as I cannot find it on the ‘net.
    I am thinking that if the dealership could have done the valve check and charged me for it, they would have. I also want to believe they would know exactly what is needed at a service and I should trust their expertise. But...
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    Quote Originally Posted by adkgsa View Post
    ....check valves every 12K (after the first check at 6K)...
    This logic would imply valve check at 6k and then 18k, 30k, 42k, etc.
    Neal - '16 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Jul 2013
    Solvang, CA
    Thumbs up Labor of love...
    service intervals on my 13RT is as follows:
    every 6000miles, engine oil/filter, GB & FD gear lube change, valve check, TB sync, new tires, check brake pads and reset service reminder...used to be every 3 months, now about every 6 months
    every 12000miles, all above but add spark plugs and air filter
    every 24000miles, all of the above and replace generator belt
    yearly, flush front & rear brakes, re-lube FD-to-driveshaft spines, check front wheel bearings/brake rotor thicknesses
    every two years, remove swingarm and re-lube tapered bearings, re-lube front driveshaft to GB splines
    just replaced the clutch/pressure plate/cover/bolts at 105000miles and tidied up accessory wiring...
    ~wyman~
    Nov 2017
    Collierville, TN
    This is right out of my REPROM. I think it's a little excessive and you guys can choose to do it whenever you want but it is every 6,000 miles (10,000 km).
    Quote Originally Posted by pappy35 View Post
    Thanks.
    Wondering why an established dealership wouldn’t follow this? Going to have to ask them to satisfy my OCD.
    That's the schedule my mechanic is using. 12k; 24; 36K etc. I get mine back tomorrow with 23 and change on the odo as a full service [ all fluids, valves, filters etc.
    30K sees an oil change, 36K sees another full service./
    Nov 2017
    Collierville, TN
    Thanks.
    I'm guessing that they rarely find clearances that need adjustment and are trying to save labor and customer cost. I do it every 6k but that's only because wrenching is a hobby for me and that gives me one more doohickey to fiddle with.
    You are probably right about this. They have surely worked on enough of them over the years.
  1. Cam head valve adjustment query
    By Blacque Jacque Shellacque in forum Hexheads/Camheads
    Last Post: 03-21-2016, 05:49 PM
  2. 2015 R1200GSA - Maintenance Intervals
    By 105258 in forum Wetheads
    Last Post: 04-17-2015, 11:49 PM
  3. 2013 R1200RT - tire pressure and valve adjustment intervals?
    By NATHANMONK in forum Hexheads/Camheads
    Last Post: 02-04-2014, 05:02 AM
  4. Oil head valve adjustment question
    By jpm1074 in forum Oilheads
    Last Post: 01-30-2013, 06:51 PM
  5. Realized 2012 R1200RT Camhead Valve Adjustment Intervals
    By liv2ride in forum Hexheads/Camheads
    Last Post: 07-11-2012, 03:58 AM
