Results 1 to 10 of 10
Thread: 1987 K75C 57k Karibic Bleu Charging troubleshoot question
    PeteG
    Dec 2009
    Woodacre, California
    Symptom(s) and current remedy
    Very low battery charge causing stuck starter relay making three delayed attempts to turn engine when off before battery quickly died.
    Replaced relay, inspection of original relay showed no fusing of contacts. It will be my spare.
    Replaced 10 year old battery with new. Ran great for 30 mile back country commute home and got a bright battery warning light upon commute-end idle. Increasing RPM would dim light. Started right up the next morning and made return 30 mile trip to shop. Again, got bright warning light upon commute-end idle. With engine off new battery had 12.58 v charge.
    Started engine and checked battery voltage at 3000 RPM and it did not move. Tested battery voltage on my other K75C at 12.6 v at rest, and jumped to 13.6 v at 2500 RPM.
    It seemed pretty clear the battery was not getting a charge. Removed alternator. Bearing felt good, contacts need cleaning, brush protruding lengths; 1 at 5mm and 1 at 6 mm. (5 mm is the service limit) Brush springs were not binding.
    I might have to call around to see if anyone can bench test the alternator. Is it likely that just the brushes need replacing if I cant find anyone local to do the bench test? I have no knowledge of whether the symptoms could indicate a bad rectifier. I already asked one local motorcycle repair veteran for a bench test reference without luck.
    Euro Motoclectrics sells a 33 Amp remanufactured Alternator for $179. The entire voltage regulator is $39. I can afford the purchase. I have no need for the 50 Amps on either of my Ks. If I wanted to solder, the brushes are available for $19.50.
    Thanks in advance for your suggestions,
    Pete
    PeteG
    Dec 2009
    Smile
    UPDATE
    1987 K75C Karibic Bleu: (I had the year wrong in my original title line)
    I replaced the at service limit 5mm brush and voltage regulator assembly. Upon assembly and voltage testing at 3000 rpm indicated no charge going to battery.
    The alternator from my 2nd 1988 White K75C with 205K mi. was borrowed for install on the Karibic Bleu. Prior to install I checked the brush length, and here is where I learned what I did not know. The 5mm service limit brush length does not mean an alternator stops charging effectively at the 5mm length, as the brush length on White K75C alternator was down to 3mm. Voltage test at 3000 rpm on the White K75C was 13.8 v with short brush length. The new voltage regulator and brush assembly was installed onto this known good alternator and reinserted into K75C Karibic Bleu.
    3000 rpm voltage test at battery indicated 14.01 v. Bleu is running like a champ as I also had discovered and replaced a split crankcase breather hose.
    Refurbished alternator was purchased from Euro MotoElectrics and am awaiting delivery to replace non-charging alternator.
    Im having an intermittent stumble-at-idle problem on the White K75C and will address on a later thread. Im chasing several theories. Battery issue or temp sensor are current suspects.
    Ride Safe,
    Pete
    Liaison 20774's Avatar
    Thanks for the update! I'll change the title for future searches.
    Quote Originally Posted by pjar View Post
    UPDATE
    I’m having an intermittent stumble-at-idle problem on the White K75C and will address on a later thread. I’m chasing several theories. Battery issue or temp sensor are current suspects.
    Ride Safe,
    Pete
    Pete,
    How many miles ago was your last valve adjustment and throttle body adjustment?
    Plugs still in good shape and proper gap?
    PeteG
    Dec 2009
    Pete,
    Hi Lee,
    Thanks for reaching out with the suggestion of tackling the easiest task first. I need to do a throttle body adjustment. I have a Twinmax but have not yet used it. That will be my next step once it gets running.
    I did a valve adjust and plug replacement a few hundred miles ago. Unbelievably the old plugs looked great other than worn and too large gap. Only one valve was out of spec and needed a different shim size. I triple re-seat and re-check gap after shim replacement so I'm thinking this isn't the problem. Performance was noticeably improved after new plugs and gap adjust. I do know my battery needs replacement since standing voltage begins at 12.6 v and after 90 seconds with the lights on (not running) drops to 11.7 v. Battery also charges unusually fast. So battery replacement and waiting for refurbished alternator is step one. The battery is a cheap 12 month warranty on its 3rd year.
    The thought just occurred to me that I should share my "valve shim PDF template" file. It is a visual and data record of all known installed shims and lets the user (me) know what the next needed shim size will be. I can make it a fillable PDF so the user can enter data as needed either on the computer or in writing as a print-out. That will be on my "to-do" list.
    I'd love to have a way to test plug wires. I cannot fathom how they are still performing after 30 years.
    Take care,
    Pete
    Aug 2003
    Marion,Ar.
    Most BMW K75 owners will tell you their Red K75's will charge faster than your blue K75. Just a little heads up.
    PeteG
    Dec 2009
    Update
    Pete
    After replacing battery, starter relay, & cleaning starter connections the stuck starter relay reoccurred after about 10 starts. I'm in the process of cleaning the ignition switch ( thanks to Don Eilenberger's tutorial things are going fairly well) and have encountered a spring and ball that I cannot figure how they position.
    The first image shows the white bottom part of the ignition. I accidentally separated it into two parts (2nd image) and found the spring and ball stuck in grease as shown. Any ideas how they position? I marked how the two parts reposition so that should not be an issue. I think I know where the ball should go, but have no idea about the spring. Feel free to let me know if clearer pictures are needed.
    Thanks in advance for considering this puzzle.
    Pete
    Nick Kennedy
    Telluride Colorado
    Pete
    I cleaned my ign switch a couple of months back using Don's picture tutorial. I did not have that ball and spring that you show.
    I had a heck of a time to get it back together.
    I ended up assembling it upside down if that makes any sense, then it came together and worked.
    Take your time and don't force anything, when its right it will easily go together, took me 2 hrs!
    Don't know where that ball and extra spring goes, sorry, hopefully someone here will chime in to help.
    PeteG
    Dec 2009
    Quote Originally Posted by nickrides View Post
    Pete
    Thanks for the reply Nick. Did you separate the two parts shown in my photo? Don's picture tutorial did not mention separating the two parts. I did so by accident. If you didn't separate those parts then you would not see anything other than the 4 springs shown in Don's tutorial. I took the upside-down assembly path as well!
    Take care,
    Pete
    PeteG
    Dec 2009
    Pete
    Woke up from a nap and think I figured out how this works. See photo. Insert spring into hole "A". Put ball on top of spring. When the two pieces are mated the ball will skid and create a stop lock at indent points B1, B2, & B3. That's my reasoning. If anyone knows for certain if that is correct please confirm.
    Thanks,
    Pete
  1. Replies: 3
    Last Post: 08-20-2018, 08:11 PM
  2. 1987 K75C 34.6K Oldest Karibic Bleu Brake Rotor Nut question
    By pjar in forum Flying Brick K-bikes
    Last Post: 04-04-2017, 06:33 PM
  3. 1987 K75C 19K Front brake rotor replacement question
    Last Post: 11-15-2015, 02:14 AM
  4. 1988 K75C 166k troubleshoot spark issue
    Last Post: 03-18-2014, 12:56 AM
  5. 1987 K75c
    By pakratk75 in forum Flying Brick K-bikes
    Last Post: 06-09-2007, 07:28 PM
