Results 1 to 9 of 9
Thread: 2014 800 gs trans problem. BOY! heres an odd one
    MY son has a 2014 F 800 gs. He's been complaining about downshifting from 3 to 2. I took it for a spin today. Yep, wont come back down. You have to really play with it. Really I feel That its all the gears. Any Ideas?
    Mansfield,MA
    Is there any evidence that the shifter has been bent?
    Mod Squad
    2009 F800GS 1994 TW200
    Make sure that the lever is tight on the transmission shift shaft. Looseness here limits the throw and makes downshifting problems.
    Not That I can tell. IT really CLUNKS when you put into gear. I MEAN REALLY CLUNKS. Nothing smooth at all. It shifts fine going up..... well I say fine.It clunks its way up but it does go up the gears. The coming back down is near impossible. As a matter of fact I had to come up the driveway in 4th. I couldn't get it to downshift at all. I'm an old airhead/Oilhead guy.These new bikes are all Greek to me. No offense to the Greeks. I just don't understand bikes very well yet..
    I'll go take a look at it now
    Mansfield,MA
    You can also check the clutch cable for proper adjustment making sure for smooth complete movement.
    Mod Squad
    I believe he may have done some real damage in the gear box. Shift lever is fine. Clutch cable play is good. At idle just putting into gear it bangs in there. I know it will bump a little but this thing Bangs into gear and jumps. Do the new gear box's have forks that move the gears like the old one's have? My oldest son is on his way over. He has a 2016 800 gs that's in perfect running condition. I'll compare the two and see the difference if any. I can't believe the trans should be that harsh when shifting.
    Mansfield,MA
    Try it with the engine shut off but with the bike moving- down hill or with someone pushing the bike.
    Mod Squad
    Nibley, UT USA
    Compare the clutch action on the two bikes and verify that the clutch is releasing properly.
    Best,
    DeVern
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
  1. K1600GTL 2014 Passenger Wind Problem
    By Fineplumbing in forum Straight 6 K1600 GT/GTL/B
    Last Post: 11-25-2015, 12:04 AM
  2. Trans leaking
    By mohan0 in forum Oilheads
    Last Post: 07-24-2012, 03:33 PM
  3. Trans clatter
    By RandyB in forum Airheads
    Last Post: 06-05-2009, 01:45 AM
  4. Trans swap
    By 72598 in forum Airheads
    Last Post: 06-04-2008, 03:57 PM
  5. trans spline ?
    By BigAlibew24 in forum Oilheads
    Last Post: 10-17-2006, 10:50 PM
