Results 1 to 9 of 9
Thread: 97 RT Spiegler brake line swap
    Amateur Surgeon romulanremus's Avatar
    Jul 2019
    Cloudcroft, NM
    I got the set of five yesterday and started the install. Had a few issues. I couldn't get the left front caliper line to break free where it goes through its bracket. The screw holding the bracket to the left fork was frozen, and a chisel didn't manage to free it up so I ended up cutting the head off. It was only after I got the line off I saw that with a little more tugging the line would have pulled through the bracket. Oh well, still down one hand for now. Maybe with two I could have gotten it.
    The big issue is the line from the ABS module to the 3-way tee mounted on the right fork. The banjo angle is incorrect, causing the end of it and the first part of the brake line to hit the telelever spring. I tried to reposition it with the banjo pointing straight down, but that made the line too short and keeps the steering from turning fully to the left.
    I talked to Brian at Spiegler and he was very helpful. They sell one kit for 95-97s and another for 98-01 1100RTs; I ordered for 95-97 of course. But it looks like I got bit by the mid-year swap-over thing. 95-97 calls for a 20ļ banjo, 98-01 calls for a 45ļ. Brian says this has never come up before as far as he knows, and he is sending me out a new line stat, gratis too.
    So great customer support at Spiegler, very happy with them. Now to run the VIN on this bike and see what I find out.
    1997 BMW R1100RT
    1976 Honda GL1000 x2
    1981 Honda CB750C
    1974 Yamaha GT80
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Spiegler has an excellent product and outstanding service.
    They are truly #1.
    I won't use anyone else.
    Ufda happens..........
    Registered User tangoalpha's Avatar
    Dec 2016
    CA Central Coast
    They are truly #1.
    Agreed 100%. Well worth the cost.
    "Der Bimmer ist wunderbar."
    Tango Alpha
    2002 R1150RT
    Jul 2019
    Cloudcroft, NM
    The replacement line should be here today or tomorrow. Iím not in a hurry as sheís on the operating table right now with her tranny removed and waiting for a friction disc.
    1997 BMW R1100RT
    1981 Honda CB750C
    1974 Yamaha GT80
    Jul 2018
    Coppell, TX
    Spiegler lines for 1999 R1100RT are on the way..
    I replaced the front brake caliper on R1100RT 2 years ago and should have replaced my lines..
    Today, my front brakes locked up and new lines, front and rear, are on the way from Spiegler.
    Thanks for the tips !
    Jul 2019
    Cloudcroft, NM
    I left everything connected till the new lines came in. I donít know if that made a difference but I had no problems bleeding the system and everything worked correctly the first time out. It also helped to route the new lines correctly leaving it all till the new Spieglers arrived.
    1997 BMW R1100RT
    1981 Honda CB750C
    1974 Yamaha GT80
    Jul 2018
    Coppell, TX
    Installed Spiegler Brakes (front and rear) on my 1999 R1100RT - Great product
    Wow, the Spiegler kit was amazing.. seriously.
    The kit for 1999 R1100RT :
    1) had each line had a sticker indicating the location of the line
    2) was a Perfect fit
    3) included a front fork 'splitter' which also fit perfectly
    Time will tell regarding quality of the lines but so far the fit and finish is perfect.
    Note, on the RT I had to remove the front fender and the right side fairing in order to get to the brake line connections leading to the ABS unit.
    I guess technically, you could try an install w/ the fairing in place, but you might fit it tough.
    Thank you to the folks on this thread for sharing their wisdom !
    Jul 2019
    Cloudcroft, NM
    I didnít think about the front fender, I already had it removed to install a Fenda Extenda to keep rocks and road schmutz out of the bottom fairing crossover and off the HES cover. Glad youíre happy with the Spieglers.
    1997 BMW R1100RT
    1981 Honda CB750C
    1974 Yamaha GT80
    Feb 2019
    N/Ca. Bay Area
    Recently had my 2000 R11RT in for full service (56k on clock) getting ready for road trip up to Vancouver BC. Then last week had the short ( left side ) front caliper hose start to leak fluid. Stupid me, way over time to change to new, braided lines. Had to have her towed to dealer in SF. Since i just had the big service just done, they ordered new Spiegler lines, $50 less then on line price, and only charged 3 hours labor which was more than fair. I could have done it myself, but im sure i would have ran into something that would have slowed me down. (Always happens). Picking her up this Wednesday and leaving Friday am. Ill take some pics and post them for the faithful oilheads. Btw, Spiegler lines are guaranteed for life.
    Well, just got back from my 2k trip. The new brake lines are great. So much more feel. Should have done it a few years ago.
  1. Replies: 13
    Last Post: 05-06-2019, 04:06 AM
  2. R1150RT Spiegler Brake Line Install Tips?
    By tangoalpha in forum Oilheads
    Last Post: 03-29-2019, 03:02 AM
  3. Spiegler Clutch Line, '00 R1150GS
    By gsbruce in forum Oilheads
    Last Post: 09-13-2012, 02:55 PM
  4. 2004 K12RS Spiegler Steelflex Brake Line Installation
    By jurgen in forum Flying Brick K-bikes
    Last Post: 12-25-2010, 10:07 PM
