Results 1 to 11 of 11
Thread: Phone charging cord in Glovebox of 2011 RT
    Just took a rip to Reno and I plugged my iphone into the charger cord in the glovebox of my 2011 RT. It doesn't work. I looked in the Rider's manual, no help there. The manual doesn't even tell where the fuses are located! Does anyone know why this cord may not be working? Thanks
    Jun 2007
    Portsmouth, NH
    The manual doesn't talk about fuses because there aren't any. The electrical system can handle shorts and reset circuits when the short is cleared.
    Sorry I can't help with RT specifics on your charger question. Did you test out the cord and make verify that the USB end of the cord was correctly aligned? Some USB A ports will allow the plug to be inserted incorrectly and a socket stashed in a dash pocket seems like it might be hard to see the correct orientation.
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    If it's a cord that you bought just for the bike it may not be an approved Apple cord, some after market cords will not work. I ran into this after the the 5 series of phones.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    May 2017
    Oregon Coast
    Is this cord intended to charge phones or to read a USB media device with music files. My RT has a short cord in the right side storage compartment with USB connector. That is to read music files and to my knowledge does not supply current for phone charging. Any chance your bike has an audio system that would play MP3 files?
    2017 R1200RT -- Riding the backroads of the pacific northwest.
    Nov 2017
    Collierville, TN
    That USB port is for streaming audio files not charging phones. I do plug in and use it when I use my phone for navigating but I need to shut off the screen between long stretches. It can only supply enough current to slow down the discharge rate (2 or 3 percent per hour). It can only charge the phone when the screen is off and even then at a very low rate.
    I am planning to tap into the GPS power port behind the headlight and run that to a proper charging USB port but so far I just haven't needed to do it.
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    Perhaps that USB port is a direct link to the "Bitch Moan Whine" division of Motorrad USA? Aren't there lots of other power outlets to charge your phone on the bike?
    Friedle
    thankful for the long battery life of my Fischer Price flip phone
    Ride fast safely
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Is there a cord or device that can add in the charging voltage to a data signal? You know, like a cord that adds the power in?
    John.
    Atwater, CA
    2015 R1200RT
    Aug 2016
    Reno, NV
    Apple in their proprietary ways requires the use of their charging cords on the iPhones, there is an additional logic pin in there and non approved cords won't work. ( I get an error message on phone that says cord not approved) Amazon carries approved short and long cords.
    Try using a cord that charges the phone at home and see if you get a charging indicator on the phone when you use the outlet from the bike.
    Krmugin
    Apr 2014
    West Coast
    There are several alternatives to add a power cord to the glovebox. USB, Powerlet, etc. You can have a fuse, and wire it to the battery. I ran mine under the gas tank, and drilled the proper sized hole in the glovebox.
    Registered User skibumwi's Avatar
    Jul 2016
    Milwaukee
    Quote Originally Posted by coastal View Post
    Yep,
    I have a 64GB USB stick with MP3 files on it attached to the USB port. I don't think the USB port provides any charge. You can get a Powerlet to USB adapter to use.
    Ski
    I don't know about the RT but on the GTL the USB connector does provide power, at least enough to keep an Ipod charged.
    Sent from my XT1254 using Tapatalk
  1. iPod charging cord 2016 R1200RT
    By pbryant018 in forum Hexheads/Camheads
    Last Post: 10-05-2017, 10:19 AM
  2. Charging my I Phone
    By Malaszka in forum Gear
    Last Post: 10-11-2012, 06:17 PM
  3. Perfect flashlight for the 2011 R1200RT glovebox.
    By IDisposable in forum Hexheads/Camheads
    Last Post: 05-13-2012, 09:00 PM
  4. Replies: 1
    Last Post: 02-02-2012, 05:32 PM
  5. Charging a phone on your bike
    By RTRandy in forum Gear
    Last Post: 01-10-2009, 12:39 PM
