Results 1 to 7 of 7
Thread: Reinstalling fuel sending unit 97 RT
    Amateur Surgeon romulanremus's Avatar
    Jul 2019
    Cloudcroft, NM
    I pulled it loose because the vapor canister is still installed and wanted to check for damage to the tube. Now I can't get it oriented to go back in and the Clymer manual that came with the bike doesn't address the RT sender. So is the trick to take the tank off, flip it and remove the fuel pump and filter unit? I don't want to bend anything I can't see down in the tank so figured I'd ask. Thanks for the help.
    1997 BMW R1100RT
    1976 Honda GL1000 x2
    1981 Honda CB750C
    Couple dirt bikes
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    You are mostly correct. If you add NSFW words and frustration coupled with beers for your buddies so they can laugh, it still won't go together according to any reason.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Mar 2010
    Vancouver, B.C. Canada
    It's been too many years since I had mine out but I recall taking out the fuel pump assembly for access. The why escapes me as it drops in from the top.
    Jul 2019
    Cloudcroft, NM
    Well I finally got it in there. Been years since I’ve hunted around in the dark trying to locate a small orifice. Now if only it still works when I hook the battery back up. And Sir Yoda, what, did you have a drone hovering outside my garage? Uncanny!
    1997 BMW R1100RT
    1981 Honda CB750C
    Couple dirt bikes
    Mar 2013
    Quote Originally Posted by romulanremus View Post
    I'm a Canuck. I don't know any NSFW words, nor is beer drinking with my buddies a constant habit (that is most unenjoyable) so if I had a drone, I would probably be shocked.
    Jul 2019
    Cloudcroft, NM
    Quote Originally Posted by dieselyoda View Post
    I dig. I don't have any buddies, wife won't let me drink beer, and I got no idea what NSWF stands for...
    1997 BMW R1100RT
    1981 Honda CB750C
    Couple dirt bikes
    Liaison 20774's Avatar
    Google says NSFW = Not Safe For Work
  1. Fuel sending unit
    By cretos in forum Wedge K-bikes
    Last Post: 10-29-2018, 01:09 PM
  2. 99 r1100r fuel sending unit
    By maredman in forum Oilheads
    Last Post: 09-25-2018, 02:49 PM
  3. 94 K75S trouble removing fuel sending unit hard stuck screw
    By mountainista in forum Flying Brick K-bikes
    Last Post: 04-19-2016, 11:12 PM
  4. Fuel Level Sending Unit Confusion
    By rkildu in forum Oilheads
    Last Post: 11-03-2013, 03:00 PM
  5. Oil Pressure Sending Unit P/N
    By r1dinman in forum Oilheads
    Last Post: 05-10-2006, 02:07 PM
