Results 1 to 8 of 8
Thread: How About Seats?
    Aug 2005
    Deerfield, Ohio
    How About Seats?
    My 1967 R60/2 has a nice Corbin seat. Problem is my vintage back hates those little tiny bumps on back country roads where I like to ride. I think it's called rebound. On suspensions where I can set rebound I can dial away those pesky sneaky little bumps that drive up my spine.
    How about the Denfield saddles? It seems to me it's a built in cushion . But I've never ridden on a Denfield. Do they come in different heights? Or for different rider weights? I'm no iron butt guy. And I have a few bikes for different kinds of rides. I'd like to be able to put more miles on this /2. The Corbin saddle is pretty good. But I have other bikes that suck up those ripples. Would a Denfield help me?
    1980 R100T
    1971 R50/5
    G650GS
    1967 R60/2, 1947 James ML
    Liaison 20774's Avatar
    Just to set it right, it's Denfeld...common mistake. That said, my R69S came with a wide bench Denfeld. Duane has a pretty good page about the varieties of these bench seats:
    https://w6rec.com/746-2/
    I was not comfortable on my bench seat, although it does afford the ability to slide around and find a better position. I preferred the look of the classic tractor solo seat, so I bought one. It is a bit more cramped, probably somewhat like your Corbin. In 2009, a friend and I drove our /2s to Sturgis, MS, for Vech's rally. It was two days each direction and I did it on the tractor solo seat.
    Maybe your rear shocks need attention?
    Aug 2005
    Deerfield, Ohio
    Oh no! Showing my extreme ignorance. I thought the Denfeld seat was the solo tractor seat. I saw it advertised at BOB's. Man I'm not looking for a bench of any kind. Like I said the Corbin is pretty darn good. BUT that tractor seat kind of springs it looks like? This one:
    https://img.bobsbmw.com/8ce9429c6d33...00&height=900&
    1980 R100T
    1971 R50/5
    G650GS
    Yes, that's the solo seat that I have. I got mine from Vech in Mississippi. I also got a rear rack which helps "finish off" the rear fender without just the round fender all exposed. I've used the rack before...I was able to strap things to it for my ride in 2009. Plus there are breadloaf seats that can be quickly bolted to the rear rack for a pillion. I believe Vech sells one of those.
    On the Denfeld solo seat, there's a bit rubber block called a silent block that provides some compliance when sitting on it. There are three positions from stiff to not-so-stiff. But where the "cushion" comes from is the rubber covering over the internal steel frame. The rubber saddle is very taught but has some give...not enough to sit on the internal frame.
    13278
    Apr 2006
    Near Lynchburg, VA
    What does the Corbin look like ?
    Photo(s) maybe.
    Charlie
    Aug 2005
    Deerfield, Ohio
    1967 r60/2
    1980 R100T
    1971 R50/5
    G650GS
    Aug 2005
    Deerfield, Ohio
    Quote Originally Posted by daz View Post
    1967 r60/2
    I installed the Denfeld and am happy with the results.
    1980 R100T
    1971 R50/5
    G650GS
    Another satisfied customer!
  1. Seats..seats..
    By helipilot2 in forum Hexheads/Camheads
    Last Post: 12-20-2015, 02:07 PM
  2. Seats
    By bdfbeemer in forum Gear
    Last Post: 04-24-2014, 03:30 PM
  3. Which seats fit?
    By getset in forum Airheads
    Last Post: 01-12-2010, 03:08 PM
  4. seats
    By wxpotts in forum Airheads
    Last Post: 08-14-2008, 05:35 PM
  5. seats
    By RGVILLA in forum Oilheads
    Last Post: 05-03-2007, 10:27 PM
