Does anyone know what the vacuum specification should be at the throttle body vacuum port? I can't find any reference to it in either of my manuals. Thanks, oldcarman jim
I don't think there is one. Too many variables. In the old days Chiltons always showed a range of values when using a vacuum guage.
My bike was purchased last year with only 10,000 on it. It had done a lot of sitting over the years but still ran pretty nice when I got it. I just finished setting my valve lifter clearances and synced the throttle bodies. Prior to that I also removed the throttle bodies, cleaned them with carb clean, very dirty and sooty. Removed the fuel injectors and cleaned them, removed the idle screws and cleaned them. Just for reference my numbers are as follows. Warmed engine, at idle, about 1,100 rpm, vacuum on each side is about 7 in. Both brass screws set to 1 1/2 turns out. At 3,000 rpm vacuum is about 8 in on each side.
