I've read a couple articles that say the fuel injectors can be upgraded to improve performance and reduce vibration. Any recommendations? Thanks, oldcarman jim
I upgraded mine almost a year ago. I jokingly say that my R1100RT has turned into my second K Bike (so smooth), or at least a soooo much smoother ride with the switch to the new injectors.
That I cannot help you with. You might email Tills directly and he might give you the info you need. He has always answered my questions, usually within 24 hours.If I understand correct you both upgraded to the R1200, 4 nozzle injector, EV14 injector. I did find this upgrade on the Euro MotoElectrics. It sounds great but I have cruise control installed on my R1100RT and the cable bracket attaches to the left side throttle body so I don't think it will work with the cruise. I did read that the EV6 injector, also 4 nozzle, from the 2004 R1100S might be a possible plug and play upgrade. Does anyone have any knowledge of this? Thanks, oldcarman jim
It’s helpful posts like this that that I remain a member of this forum. You Oilhead guys, both current owners and past who continually share your knowledge so freely to help others I find inspiring. I cannot tell you how much I appreciate you guys for the knowledge and insight I’ve gained from you since buying my RT nearly 3 years ago and upon becoming a member.
This post is one that I will be saving for future reference as I’ve just added fuel injector upgrade to my “future project list”.
Mine are on the way! Can't wait!
I read this and it seems like a no-brainer. I have a 1998 R1100r, and I'm all over this! (I couldn't think of any negative angle to this at all )
Many Thanks,
Cam
Cam,
Which set did you buy? I assume you ordered through Tills? They offer a matched set for 120. Euro and a new set for 150. Euro. There is reference to adapters which apparently are needed for the R1150 models. Not sure if those adapters are included with either of the two sets above or if they’re needed at all.
While I research upgrading to a newer design fuel injector from the Bosch EV1, I decided I'd clean mine and reinstall them. Attached are a couple pics showing this process. Essentially I just connect the injector to a pressurized carb cleaning canister and use 12 volts to actuate the injector. This shoots pressurized cleaner through the injector, cleaning it. It also allows you to see the spray pattern. I purchased a repair connector from NAPA so I could connect 12 volts to the injector. Echlin CRB 218545 or BWD 28423 repair pig tail connector. It is important when you actuate the injector to pulse the power on off or you can damage the injector. I connected the wires to a 12 volt car battery I had in the garage. I ordered a kit with new O-rings, from Euro Motoelectrics.
I installed my injectors today. Straightforward instructions, the only trouble I had was replacing the fuel line on one side. You have to really press down hard evenly on the plastic collar to secure with the square retaining clip. Apart from that, an easy job. My R1100r had plastic covers over the injectors that do not fit anymore, with the longer injectors, but that's ok.
I'll tell you why it's ok....
Wow.... just wow
It's like a whole new bike! Smoother, noticeably more punch, I kept thinking I was in 4th gear on the highway ....
maybe this is what a 1100 oilhead should run like I don't know, I have only had my 98 for a year now, and I'm sure my original injectors were in dire need of a sonic clean.
My rating on the injector upgrade is a solid 10, bang for buck.... and you can't put a price on revealing a new punchy personality to a bike.
