Another issue with long term ownership of the R1100RT is that the tank is plastic and it stretches over time. I have had to worm out my six mount holes so the the side fairing panel holes will reach the nuts in the tank which cannot be replaced as far as I know. They appear to be embedded.
I've taken my fairing off well over fifty times by now and over time discovered that by placing the nose screws and between the tank and seat rear screws in first makes linking up all the other ones a LOT easier. And never finish tighten any of the screws until they are all started and threaded in a bit. THEN go around and carefully tight them up by hand with a hand held driver. Don't use electric drivers or ratchets to do this. Be gentle!
By the way, fifty times removal and not broken one of those front tabs off? I can only dream I make it that far.
He thought he'd help and he pulled the left nose section straight out right, no angling and sliding, just pulled it.
So true on needing to worm out the tank holes. I thought I was the only one to do it. I think I have three done at this point. Which are the "nose screws? I'm trying to visualize the procedure you suggest, as, oh yes, I need to remove my 1100 RT fairing once again for a few maintenance jobs. The tank screws are the worst part, as we all know.
