I need to replace the O2 sensor and I have read that I might as well service the shift linkage with new grease, since it has to be removed for this procedure. What grease is indicated for this application? Also, I understand the rubber washers may need to be replaced. Do you have a good source or a simple DIY replacement? Any performance improvements over factory?
