Results 1 to 15 of 27
Thread: Tires "Scalloped"
    Jan 2015
    Pickering, ON, Canada
    Tires "Scalloped"
    I've been running Michelin Pilot 5's on my 2014 RT for a year. Despite them "not being recommended" by Michelin for the RT, so far I've been very pleased. Apart from the road noise (which is noticeable) that others have mentioned they have worked well for me.
    I have 6,500 miles on them (which is pretty much all that I ever got out of Pilot 4's) and am about to head off for a trip for a week so I checked them out. I am pleased to say that there is plenty of tread depth left on them, but both the front and rear are really "scalloped". How does the scalloping affect the tire (other than increasing the above-mentioned road noise)?
    Am I good to ride with these until the tread wears, or does scalloping affect their traction and/or safety?
    My Pilot 4's usually ended up being scalloped towards the end of their lifetime, so I have been running my tire pressures +2psi over the recommended to "reduce" scalloping. It doesn't seem to have helped and/or may have made it worse?
    Bob
    2014 R1200RT
    Nov 2017
    Collierville, TN
    How long is the trip?
    When I bought my bike (used) early last year the dealer put an inexpensive set of ContiMotions (non-GT-like sidewall). They were fine traction-wise but they really started howling from the scalloping (which isn't affecting your road noise, it is the cause of your road noise). That was the first indication to me that there might be something to this GT-strength sidewall stuff.
    I've got Bridgestone Battlax T31 GT's on it now and two thousand miles later they look like they are brand new and the bike feels like it's much better planted than it ever did. I'm thinking that most of that is having a stiffer sidewall. The bike used to kind of wallow in the turns, which I thought was the shocks wearing, and now that's completely gone.
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by bobs_one View Post
    You should be fine.
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    The correct tires operating at the correct inflation pressures will go a long way toward alleviating scalloping tires. Remember there are only two small patches of rubber separating your butt from the pavement. Not the place to save a few bucks.
    Friedle
    Ride fast safely
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    I have gone through several sets of the PR series of tires and most were taken off when they scalloped bad enough that bike wouldn't hold the twisties.
    I was getting about 10k-12k (kilometers) per set and was comfortable with that performance.
    My last set, I dropped the tire pressure 2 PSI below the minimum recommended for single up riding and I just changed them at 16K (kilometers).
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    ďThe major civilizing force in the world is not religion, it is sex.Ē
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    My 07 RT, 08 R12R, FJR and 17 GSA all tended to scallop the front tire. All responded positively to increasing the tire pressure to 40 PSI. I havenít had any scalloping since I began using the increased pressure. However, in my experience once a tire starts scalloping there is no reversing the process.
    Kevin Huddy
    wanderer
    Jun 2009
    Bridport Vermont
    Is scalloping really bad? Or is it just a measure or indication of how we ride?
    It clearly is only uneven ware in small areas of the tire. Over the width of a tread block, usually off center on either or both sides.
    Is this due to to low tire pressure?...many avoid this by keeping pressures on the high end of spec.
    Is it due to dual compound tires and more aggressive riding in the twisties, wearing the softer compound out faster? Seem so to me.
    On the front, is it due to consistent heavy braking?
    On the rear, is it due to consistent heavy handed application of the throttle?
    Other than low pressure, all this seems pretty normal for soft compound motorcycle tires. (Do we really want hard 50,000 mile car tires?)
    If my tire pressure are in spec, I just ride the tires out...replace them when worn out.
    If seeing scolloping really bothers, buy harder compound tires...they are usually cheaper too.
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    Quote Originally Posted by vtbob View Post
    Motorcycles in New York state must be inspected once per year. You may get an inspector who fails a tire based on it being scalloped.
    I had no problems with scalloping on Anakee III's or PR4 Trails on my wethead GS and had no problems on my 2003 R1150RT. I ran the front tire a bit higher than what BMW called for.
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
    May 2012
    DeSoto MO
    I know Iíll get push back here for this comment, but in my and several of my friends experience, dynabeads, if properly installed, pretty much stop the cupping. But must be utilized from start of use. Will not do much good now. Your choice when installing new tire, and must be installed with no possibility of contacting tire lube, soap film etc when setting the bead. Otherwise clumping will occur and youíll hear the comment about snake oil etc. Iíve had them in Pr 3s on my k1200 and found the ride smooth as silk at 120 mph riding n Montana and no cupping during the life of the tire. Used them in Heidenauís and although a work to bead with minimal tire lub, experienced the same results. Have them in my front 1200 Yamaha Tenere in a Michelin Anakee three adventure but only 2000 miles on them so far. Didnít put anything in n rear nor did I balance rear statically just to run a test to see if it makes a difference or not. Should put another couple thousand miles on them over four corners rally. Your choice obviously, and like I said, there will be much push back here on my comments. BTW up to this point in my ride life, usually a 15000 to 20000 mile annual rider.
    Jan 2016
    Arvada, CO
    Michelin=the most overrated tire for your RT, IMHO of course. I think it's primarily brand reputation, the lovely ornate siping, and that's about it. PR4GT's were on my '16 RT new, and they got very significantly scalloped in well under 2K miles at BMW's recommended pressure. Of course we learn the work around is accept the to shrunken contact patch that comes from increasing pressure by 10% or so, to 40psi on the front. That does help retard the rate of cupping but geez do you really like to pay top dollar for an ST tire and then have the bloody thing scallop like that? Why? Inevitable? Not in my experience. Continental RA3 GT has been so superior to PR4GT, Angel GT, and Metz Z8 for me I'll never use another tire model again: best turn-in and line holding, handling, no howling in turns or other undesirable noise, shape retention, zero scrub-in required, and traction so good my strips shrunk from increased confidence alone after 4 other sets of other tires tired, and no scalloping at stock psi. They were recommended to me by an uber aggressive rider who uses them on his R9T (non GT variant).
    Jan 2015
    Change from Michelins
    Quote Originally Posted by ncpbmw1953 View Post
    Continental RA3 GT has been so superior to PR4GT, Angel GT, and Metz Z8 for me I'll never use another tire model again.
    Thanks - I know tires are subject to a variety of opinions (only second to motor oil), but I'm at the point where I think I will try something other than Michelins. What kind of mileage do get from a set and do you ride only one-up, or some two-up or what?
    Bob
    2014 R1200RT
    Left Coast Rider
    Nov 2011
    I've got 6,000 km on my RA3s and they look like new. One-up sport-touring with about 20 kg of luggage on a K1200S, usually at about 110-120 km/h. I run them at 36 psi front and 42 rear.
    Jan 2016
    Arvada, CO
    One up. I have ridden these w/ luggage loaded in heavy rain as well. I can give you an estimate is about it because the first rear RA3 took a big deck screw at 5,710 miles so I replaced it. When this happened I measured tread depth in standardized points on the tire w/ 5,710 miles on a new RA3 I had installed. From this I projected out around 10,500m should be in the ballpark if that same tire made it to end of life. That is about what the PR4GTs gave me. I have ~2,500 on my replacement rear now. Here's another thing that really struck me I just now remembered: when I picked up the bike w/ the new rear RA3 I was struck by the fact it felt absolutely no different than the original tire at 5,710m that took the screw. In my experience new tires always felt much better than the spent ones just replaced. Maybe that's more true w/ the front tire I don't know. My front tire has 8,210 and still looks and feels great.
    One Man Wolfpack Kent Niederhofer's Avatar
    Jul 2010
    West Bloomfield, MI
    Tire Scalloping
    Scalloping, or what is more appropriately referred to as cupping, is a sign of a suspension setup problem. I had a similar issue on my 2009 K1300S's rear tire which was a Continental SportAttack 3. It was related to low speed damping as I had the suspension setting dialed in for one passenger without luggage when I was carrying two fully-loaded side cases and a textile top case stuffed full of gear and clothing (probably 40 - 50 lbs. of additional weight plus a 15 lb. "rider premium" for what BMW calls the average rider (185 lbs.)). The following is a lengthy video on the topic of unusual tire wear but I found it so fascinating and insightful I watched it twice. Hopefully you find it useful as well:
    http://www.onthethrottle.com/howto/d...ung-tire-wear/
    Good luck with your diagnosis!
    Kent
    Dec 2010
    Peoples Republic of Ma.
    I have a 2016 RT and got almost 13,000 mi on my 4's before replacing them recently. No scalloping or cupping. My 2000RT with PR2's cupped(front) after 2000mi.
  1. Replies: 9
    Last Post: 04-21-2013, 07:19 PM
  2. Shinko Announces "Smoke Bomb" Tires
    By Pauls1150 in forum Campfire
    Last Post: 08-20-2011, 11:21 PM
  3. Replies: 18
    Last Post: 11-20-2007, 11:44 PM
  4. Transforming Light TRK into "sport bike": shocks & tires?
    By wellsvilleangus in forum Flying Brick K-bikes
    Last Post: 08-01-2005, 09:10 PM
  5. Replies: 10
    Last Post: 08-01-2004, 02:10 AM
