Results 1 to 5 of 5
Thread: 2012 final drive question
    I've had the final drive fluid changed twice in 12K miles BUT
    The splines/gears [ not sure of the correct terminology ] at the rear of the drive have not been checked to see if the boot has let water in. I don't ride through streams, it saw several days of heavy rain last year heading to Ak. but that's it. 23K on the odo
    Should I have my mechanic break it open and check the gears for rust issues. It's been bugging me since I saw one whose gears were completed rusted but had not caused problems for the owner [ yet ].
    Is this something I should have checked while it's in for oil change/plugs/valve adjustments? Or is it, as my mechanic states, something rarely checked on a scheduled basis?
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    Quote Originally Posted by brownie0486 View Post
    Sure. It only takes a few minutes.
    Thanks, he's a busy guy so if it was a lot of time involved I might not have him do it. Just a few minutes, I want him to check it,
    Jun 2009
    Rochester, MN
    You can easily see surface rust by pulling back on the rubber boot with a strong flashlight. Though not 100% always accurate, if you have a lot of surface rust, you can bet that your splines aren't perfect either.
    I periodically pull back the boot to check for water intrusion, just make sure you fully seat the rubber boot when you're done taking a peek. As Paul noted, it doesn't take an experienced home or pro mechanic to get in to check (and they may as well lube it up while they are in).
    thanks, I think I want the mechanic to re-grease as preventative maintenance anyway
  1. 2012 BMW R1200RT Final Drive leak 27K miles
    By gtrider_texas in forum Hexheads/Camheads
    Last Post: 11-11-2018, 12:22 PM
  2. Final drive question
    By Jinxman69 in forum Airheads
    Last Post: 04-28-2015, 09:52 AM
  3. 2012 R1200RT Final Drive oil volume
    By selledr in forum Hexheads/Camheads
    Last Post: 07-12-2014, 11:53 AM
  4. Camhead final drive lube 2012 R1200GS
    By sloride in forum Hexheads/Camheads
    Last Post: 03-12-2013, 02:59 AM
  5. Final drive question
    By 2slow in forum Airheads
    Last Post: 12-24-2011, 04:49 PM
