Results 1 to 7 of 7
Thread: Help, stranded rider 2017 GS
    Apr 2006
    Nibley, UT USA
    After a fuel stop engine will crank but fuel pump does not engage and motor won’t start. Canbus has been reset, sidestand switch and engine cutoff switch checked, no joy. What’s the next item to check?
    Thanks,
    DG
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    Nov 2017
    Collierville, TN
    Quote Originally Posted by GTRider View Post
    Thanks,
    DG
    Where are you stranded?
    Apr 2006
    Nibley, UT USA
    Not me, another rider on another list. Better chance here of getting usable suggestions, tho, as to what the issue might be.
    Thx,
    DG
    DGerber
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Thx,
    DG
    The location helps in-case there's someone who lives close by.
    Lee
    2016 R1200RS
    MOA # 30878
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    A mechanic in Seattle showed Annie how to do what he called a “simple reset” when she was having TPS problems. If the bike has keyless ignition, then with the bike turned off push the ignition button four times with each push about one second apart (long enough for the bike to turn on/off). There should be an audible click after the 4th push. That’s all I got.
    Kevin Huddy
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    I've nothing to add but this would get more eyeballs if moved to the Wethead forum.
    Neal - '16 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Apr 2006
    Nibley, UT USA
    Bike and rider towed to dealership, so situation under control.
    Thanks,
    DG
    DGerber
  1. Stranded in Nebraska
    By CoffeeGuy in forum Oilheads
    Last Post: 07-14-2010, 06:40 AM
  2. Help Stranded In Fairbanks
    By Ozonkiller in forum Oilheads
    Last Post: 07-02-2008, 04:51 PM
  3. Not Quite Stranded
    By BobMielke in forum Hexheads/Camheads
    Last Post: 12-22-2007, 03:25 PM
  4. need help, rider stranded
    By bmwbubblehead in forum Oilheads
    Last Post: 03-25-2007, 09:36 PM
  5. Help! Stranded in Stewart, BC
    By Chuck in forum Campfire
    Last Post: 01-25-2007, 11:26 PM
