Any PIAA 1100 Replacement Bulbs?
Paul_F
RK Ryder
Apparently PIAA no longer supplies replacement bulbs for their 1100 auxiliary lights.
Has anyone found a replacement for these bulbs that fit the 1100 holders?
An H3 should fit. If not, I would recommend these. I have had excellent service from a pair of these as had a good friend of mine.
I've replaced the bulb with a bulb that I got at Canadian Tire. IIRC it was a standard 55w h3 bulb but the original PIAA bulb had a longer wire. I just extended the wire and covered the connexion with shrink tubing.
