Results 1 to 8 of 8
Thread: Any PIAA 1100 Replacement Bulbs?
    RK Ryder
    London, Ontario
    Apparently PIAA no longer supplies replacement bulbs for their 1100 auxiliary lights.
    Has anyone found a replacement for these bulbs that fit the 1100 holders?
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    Gary Phillips - #6322
    Wildland Firefighter, Retired, Riggins, ID
    Heartland Moto Locos BMW Riders
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '00 R1100RS
    RK Ryder
    London, Ontario
    Quote Originally Posted by 6322 View Post
    Thank you.
    I'll give their locations a call and plan on a ride to one of their shops, since they apparently do not mail the bulbs. I better stock up on with more than just one.
    Paul F. Ruffell
    RK Ryder
    London, Ontario
    Unfortunately Pepboys no longer stocks this bulb.
    Back to my original question; has anyone found a replacement that will work in the PIAA 1100 housing?
    Paul F. Ruffell
    AZ
    It is an H3 bulb type. Here is an LED replacement
    Here is the original available from Amazon:
    MOA #107139
    RA #28511
    RK Ryder
    London, Ontario
    Quote Originally Posted by azgman View Post
    Unfortunately neither of the above will fit in the PIAA 1100 housing unit.
    Paul F. Ruffell
    AZ
    An H3 should fit. If not, I would recommend these. I have had excellent service from a pair of these as had a good friend of mine.
    MOA #107139
    RA #28511
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    I've replaced the bulb with a bulb that I got at Canadian Tire. IIRC it was a standard 55w h3 bulb but the original PIAA bulb had a longer wire. I just extended the wire and covered the connexion with shrink tubing.
    Pat
    Ride Safe!
    '16 RT
  1. PIAA bulbs
    By cajunjohnny in forum Gear
    Last Post: 06-10-2014, 03:35 PM
  2. Replies: 1
    Last Post: 12-23-2012, 11:21 PM
  3. PIAA bulbs.....?
    By Cycl2day in forum Gear
    Last Post: 08-05-2011, 05:40 PM
  4. Headlight bulbs by PIAA!
    By Polarbear in forum Airheads
    Last Post: 12-30-2007, 11:55 PM
