$500 for a case that's smaller than the 39L Shad case AND $150 more. Just because it's got the roundel on it doesn't make it better.
Shad or Givi is the way to go. Givi is more popular, and so there is wider availability and more accessories (such as lighting).
.........but, but, but, the Roundel matches the bike.
Many models of Givi cases will happily allow you to close and lock the top case without a key, locking said key inside the case in the pocket of the riding gear you just tucked away safely.
I'd vote for BMW's 28L case - excellent design and fit, and often available used instead of new. When you're finished with it, it's easily resold here in the Marketplace.
Many models of Givi cases will happily allow you to close and lock the top case without a key, locking said key inside the case in the pocket of the riding gear you just tucked away safely. DAMHIKT.
Shad cases require a key in order to lock, so the key is in your hand. That right there is why I went with Shad over Givi on my K1300GT. Quality-wise, I’d rate the two brands as equal.
Best,
DG
