Results 1 to 11 of 11
Thread: Tube tire help 2011 R12R
    While at the rally, we had the tires and tubes changed at No-Mar on Wednesday. We used the bike sparingly around LEBANON for the rest of the week and then returned home to Alabama 315 miles from rally site. The bike ride wonderfully and the new tires were awesome. The bike has sat for one week. This morning we were going to take a ride and low and behold the front tire was flat. There is nothing punctured and the tire looks perfect. What could be the cause of the tire going flat. I would think it has to be with the tube?? Am I right in that assumption? This is the only bike we have ever had with tubes and the only time we have changed the tires since owning it.
    Sent from my iPad using Tapatalk Pro
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
    Mansfield,MA
    Yeah, the tube holds the air. If the tube was ďpinchedĒ during the tire change you would have known right away.
    Itís soapy water time. I would check the valve core first- air up the tire and put soapy water on the fill core. If nothing, a slow tube leak will frequently show at the hole in the rim where the valve comes through.
    Other than that, itís spin the tire and inspect for the cause.
    Mod Squad
    2009 F800GS 1994 TW200
    Thank you OM, will check it out...I was thinking that it might be at the stem or valve core. The tire looks perfect....and when we pulled up Sunday after the rally...it felt good ...granted I didnít check air pressure....but we did go from those nice temps in Tennessee back to the mid 90ís once home and itís been pushing 97į almost every day since..donít know if that has a part to play in the process, but I will check it out
    Sent from my iPhone using Tapatalk Pro
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Brian was it a loose valve core or tube puncture?
    Lee
    2016 R1200RS
    MOA # 30878
    Yes sir! It was a pinched tube
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
    Mansfield,MA
    Quote Originally Posted by brianhinton View Post
    Interesting, my pinched tubes have shown up right away
    Mod Squad
    I have, over the years, had a couple of cases where a pinched tube stayed pinched enough to hold air for a few days and miles. Then tire squirm allowed the tube to shift a little and open the defect and allow all the air out ASAP.
    May 2003
    SW Iowa
    I would have bet good money it was not a pinched tube because it took so long to deflate.
    It's a good thing I don't gamble
    Lee
    2016 R1200RS
    MOA # 30878
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Question..... I am confused by a 2011 R1200R using tubes. What have I missed, please?
    Kevin Huddy
    Sep 2006
    CENTEX USA
    The Classic model, black with white accent tank stripe, has spoked wheels.
    Bro in law has one and keep trying to get him to have Woody's do the rim wrap conversion
    to convert to tubeless. There is a thread on ADV about another vendors process with silicone tape and dots over the nipple heads.
    Having a flat headed to Iowa last year on day one was aggravating to say the least on a modern bike.
    The Nine-T has two variations or more with non GS style radial spoked rims that also run tubes. Not a fan
    Jul 2007
    Thanks, Steve. I had assumed the spoked wheel variants came with the same sort of tubeless spoked wheels as the GS/GSA.
    Kevin Huddy
  1. 07 R12R - Anyone using a non touring rear tire?
    By fletchdude in forum Hexheads/Camheads
    Last Post: 02-20-2013, 09:32 PM
  2. 2011 R12R rear-wheel not easily free-spin in neutral
    By Patch in forum Hexheads/Camheads
    Last Post: 09-12-2012, 02:01 AM
  3. Tire Tube Question
    By bustedknuckles in forum Airheads
    Last Post: 08-10-2011, 01:03 AM
  4. 2011 R12R Tall Shield Bracket (or, lack of)
    By ljlangston in forum Hexheads/Camheads
    Last Post: 05-19-2011, 06:41 PM
  5. New Tire...New Tube???
    By Sailingfool in forum Campfire
    Last Post: 04-01-2010, 12:18 PM
