Results 1 to 13 of 13
Thread: Special tools needed for valve adjustment
    Sep 2015
    West Lafayette, IN
    I cannot find the TDC tool or the cam chain tool in order to adjust the valves on my RT. Are the tools really necessary? Any others necessary if so?
    Registered User cap's Avatar
    Oct 2016
    Fort Collins, CO
    Cool
    Quote Originally Posted by Knobby10 View Post
    I got the complete set from Bike Bandit ... for example, https://www.bikebandit.com/oem-parts...27790/b3196338
    There are 4 tools in the complete set: the alignment pin, the alignment gauge, the cam chain tensioner, and the tensioner sleeve.
    Registered User kunkies's Avatar
    Dec 2018
    Charlotte, NC
    Anyone know the BMW OEM part numbers for all four (4) tools?
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    You need none of those tools for a valve check and adjustment.
    Lee
    2017.5 R 1200 GSW
    Mar 2010
    Wills Point, TX
    You don't need special tools to check and adjust the valves, just a straight edge. Get JVB Produciton DVD http://jvbproductions.com/
    Jay
    Mansfield,MA
    Have a peek here- https://forums.bmwmoa.org/showthread.php?93365-TDC-tool
    And don’t forget to check the Wethead index “sticky” in this forum area.
    Mod Squad
    2009 F800GS 1994 TW200
    Oct 2016
    Fort Collins, CO
    Quote Originally Posted by kunkies View Post
    Part # 83 30 2 327 796 Cam alignment tool
    Part # 83 30 2 327 790 TDC tool
    Part # 83 30 0 444 292 Cam chain tensioner
    Part # 83 30 2 339 885 Spacer ring for tensioner
    Oct 2016
    Fort Collins, CO
    Quote Originally Posted by LFarling View Post
    Yes, and you DO need the tools to check cam timing.
    Quote Originally Posted by cap View Post
    In 59 years of driving cars and 950,000 miles riding motorcycles (mostly BMWs) I have never had a need to check valve timing or camshaft position. If this is the new normal for BMW engineers they need to go back to school.
    Albuquerque, NM
    There is no call for cam chain adjustment check in any service information from BMW.
    http://cdnmedia.endeavorsuite.com/im...%20Service.pdf
    Kent Christensen
    21482
    Oct 2016
    Harrisburg, PA
    I have checked over 30 cams.
    From 3000 miles to 81,000 miles, GS/GSA/RT.
    At least 15 of those were out!
    And more had the cam postilion sensor off which exhibits as a hard start or even a need for a second push of the start button.
    I did 4 at JVB Productions Yearly Tech meeting and 3 were out!
    Since I have not even tried to put some kind of degree wheel on the cams to try and figure out how many degrees they are out I have no clue how far or if they are retarded or advanced.
    And to be fair the jig is a tight fit it either goes on or not. Some have been slight but others been way off.
    I do not think BMW has quality control any longer. Soft cams, bad rear master cylinders, limp mode coming from no where with no warning reason.
    Lee
    2017.5 R 1200 GSW
    Do they sell as a set? Link gives only one Item, do I locate each item myself to make the set or do they sell an actual set, sorry long night working trying to be lazy,
    Edit, OK before I get crucified, like I said been a long work night, I think I figured it out. Once I allowed my mind to eliminate the spaces in the numbers I can see what's going on. Sorry.
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Does BMW ever fix an older bike with a problem? I have a 2015, 60k miles... Yeah, it hard starts sometimes... Or, is this an adjustment thing?
    John.
    Atwater, CA
    2015 R1200RT
  1. Replies: 5
    Last Post: 10-25-2018, 02:11 AM
  2. Rebuilding a clutch without special tools.
    By Roguetek in forum Airheads
    Last Post: 09-09-2013, 06:29 PM
  3. Replies: 6
    Last Post: 02-11-2013, 06:32 PM
  4. Special tools
    By robertklee in forum Gear
    Last Post: 05-28-2009, 12:49 PM
  5. Airhead special tools
    By robertklee in forum Airheads
    Last Post: 04-09-2009, 01:02 AM
