Results 1 to 14 of 14
Thread: Final drive options
    Registered User jnrugg's Avatar
    Sep 2007
    Danielson, Ct.
    Final drive options
    On the way home from the MOA rally in Tn. it appears the final drive went out again.
    It was redone by Max's 4-5 years ago with the new bearings.
    In thinking back there were many clues that there was an issue but I never picked up on them.
    My question is, is there an alternative to rebuilding it and having it redone every few years?
    Does someone or is there some tech that would make it more reliable?
    I keep up on the drive oil changes and had just put in new oil before the trip.
    But there were some very subtle clues even end of last year.
    Right now it's at Bob's BMW in Md.
    2002 1150RT with 107k+ miles.
    TIA!!!!!
    Feb 2005
    Trinity, NC
    How many miles were on the rebuilt drive when it failed? I have about 100k miles on my big bearing rebuilt final drive, with no indication of pending failure, knocking on wood.
    What were the signs that you wish you paid more attention to?
    Sure, itís a wear item, but without extreme usage the bearing should last a long time.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Sep 2007
    Danielson, Ct.
    Don't recall the miles when it was done, a guess would be around 80k+ miles.
    Sometimes when going around a corner I would feel the back kick out a little, like the tire rolling over a stone.
    Some noises that sounded like it was coming from the front, I thought it was a front tire problem and was going to take it in when I got back.
    Planet Earth
    Probably not shimmed correctly. You might try largiader.com. He is fairly close, and does excellent work. Or, pickup a used FD on ebay, and rebuilt the other one once you get home.
    May 2008
    Western Massachusetts
    Quote Originally Posted by 23217 View Post
    I'd second this advice. Pick up a used final drive off of E-Bay (~$2-300) and then have your unit rebuilt as a spare.
    As for signs of impending doom, my warnings were an unusual, thought subtle, howl when at speed, and gear lube streaks on the right inside of the rear wheel.
    Good luck.
    Sep 2007
    Danielson, Ct.
    I got the howl but not the oil. When it went the first time about 5 years ago, I got the oil but not the howl and was able to ride it about 1 1/2 hrs. back to the hotel.
    Still waiting to hear from Bob's, but will contact largiader to see if they have a unit available.
    Maybe Bob's can just swap it out rather than rebuild.
    Vancouver, B.C. Canada
    It surprises me how many repeat failures there are on 1150 final drives that were "fixed" by a dealer. They don't seem to know how to properly shim them.
    Anton certainly does. Over here on the Wet Coast we're lucky to have GSAddict as a great alternative. He has repaired a lot of 1150 final drives and I have yet to hear of any failures after he has shimmed them. Including his own 1150GS which has tons of miles on it now.
    Planet Earth
    I agree. The method used by dealers seems to be flawed. I prefer the solder method with the correct preload. Anton does know how to do it correctly, which is why I recommended him. And, he is close by.
    Sep 2007
    Danielson, Ct.
    I had a very nice conversation with Anton. Bob's can't get to it until mid July at the earliest.
    After reading these posts I don't know that I would want them to either.
    We are looking on getting it to Anton's, over 2 hours away from Bob's.
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Anton is your man.
    Ufda happens..........
    Sep 2007
    Danielson, Ct.
    Anton rebuilt it while I was there.
    He has great patience to have a customer watch him work.
    He did find that it was shimmed tighter than it should have from the dealer.
    Quote Originally Posted by jnrugg View Post
    Almost every one I do was too tight. That is why simply replacing the bearing is not a long term fix.
    Apr 2009
    Huntersville N.C.
    I couldn't agree more. I have rebuilt over 125 of this style final drives & 99% of them were over shimmed. There are three other problems with this final drive that need to be fixed during a rebuild. I rebuilt a final drive that had over 300,000 miles on it & it was in great shape it had the correct preload on it.
    Dave Selvig
    2008 Black LT
    2004 Black LT
    2000 Canyon Red LT
    Quote Originally Posted by saddleman View Post
    Too bad most dealers don't do the shim check.
  1. 04 R1150RT Final Drive Rebuild Options
    By 2dflier in forum Oilheads
    Last Post: 07-23-2019, 04:49 AM
  2. Replies: 5
    Last Post: 07-05-2017, 09:43 PM
  3. Swap a K75RT for K75S Final Drive& Drive Shaft?
    By 128465 in forum Flying Brick K-bikes
    Last Post: 05-19-2012, 05:32 AM
  4. corrosion on shaft drive and final drive cover
    By usna92swo in forum Oilheads
    Last Post: 12-01-2008, 12:01 AM
