Results 1 to 15 of 20
Thread: '78 R100/7 Loosing Power High Speed
    I bought this bike in stock condition 3 years ago and when I would hit about 65-70mph it would bog down like someone was pinching the fuel lines on and off really quick, or flipping a switch back and forth really fast disconnecting the spark plugs - sort of a sputtering behavior. I ruled out a vapor lock in the tank by opening the lid at speed. Strangely this behavior does NOT repeat itself in 4th gear hitting the same RPM, only in 5th gear at 65-70mph. It's definitely not the clutch going bad as proposed in another similar post.
    So I thought it might be a carb issue and since I was using this as a donor bike for a custom restoration (see below) I figured rebuilding both carbs would correct the behavior. Unfortunately after total rebuilds of both 36mm Bing carbs with new diaphragms, O-rings, needles, floats, jets etc. and a thorough cleaning the problem persists.
    Any ideas?
    Feb 2005
    Trinity, NC
    Diaphragms were going to be my first suggestion, but you say that you replaced them. With Bing replacements?
    Have you checked valve clearances, and have you checked compression?
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Maybe check or replace your inline fuel filters, and also check the petcock screens. A partial clog may be reducing the fuel flow just enough at certain speeds to cause the sputtering. I would also check that the floats are set to the correct height.
    You might also check that your carb slides are working smoothly, and that the new diaphragms are installed with the notch in the right position.
    Good luck!
    ECJ
    Liaison 20774's Avatar
    Welcome to the forum! I'll add check your air filter...had an R100RS that was restricting high speeds...it was a dirty air filter.
    Just to be clear, the bike accelerates and cruises normally at all rpm ranges in the first 4 gears but not in 5th? That's very odd. I would try to repeat the symptoms going up hill in 3rd and 4th. If they don't repeat, it doesn't sound like a fuel/air issue. I would still replace air and fuel filters, and fuel lines, as others suggest, low hanging and cheap fruit. If not, it's speed related and all I can think of is wind moving something that either blocks the air intake or causes a bad plug wire to flutter and cut spark. Are the plug wires new?
    '61 Clubman's Gold Star, '13 690 Duke, '13 Daytona 675R, '17 1290 GT, '18 Street Triple RS (gone but not forgotten: '76 R75/6, '84 R100, '76 R90S)
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Tune up Mantra
    The tune up Mantra for airheads as I understand it is as follows.
    1: Compression, Check to see if it is proper 150psi or so. (If you have a leak down tester perform a leak down test.)
    2: Valves, see if they are set to proper clearance. (Not sure the mileage on the bike so I will assume they are not worn out. IF they will not hold proper gap, it is a sign they are worn or receding.)
    3: Timing and in your case points. Check the points for proper gap and wear. After the points are properly gapped check for proper timing. (A possible problem could be the points condenser has gone bad. I have seen this happen in two bikes of the same year.)
    4: Carbs, You have rebuilt the carbs. As suggested, check the filters in the tank. Check for water in the gas. IF the bike has been sitting with gas in it, you could have rust, water, or both causing fuel flow problems.
    Do your troubleshooting after you have done the steps above.
    From my armchair here at home, I suggest replace the condenser. Sometimes, the points get replaced but the condenser doesn't and they quit or break down with time. St.
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    Float level.
    F.O.G.Rider, Rounder #6,
    Ambassador, WI Airmarshal
    BMWRA Wisconsin Region Rep
    Aug 2003
    Marion,Ar.
    Check your gas tank cap vent. Could be stopped up.
    Quote Originally Posted by barryg View Post
    He said he opened the "lid" while at speed. Seems to rule out the gas cap vent.
    But float height sounds like a good candidate!
    Open exhaust = none stock carb settings
    Looks like you have some low restriction mufflers on there. Have you tried bigger main jets and or needle setting change?
    Quote Originally Posted by MANICMECHANIC View Post
    Float level.
    +1.
    I had precisely the same behavior from my ‘91 R100 that I did my first carb rebuild a month or so ago. Steve Strickland at Motoworks (Chicago) re-did my rebuild, and adjusted the float levels. Voila! The bike now keeps up with interstate traffic without a problem. Fuel depth in the bowls should be 18-22mm when the floats are properly adjusted. Yours feels like it’s running out of gas because it probably is.
    B Reams brook.reams's Avatar
    Jan 2007
    Arvada, Colorado
    Quote Originally Posted by khittner View Post
    +1.
    I had precisely the same behavior from my 91 R100 that I did my first carb rebuild a month or so ago. Steve Strickland at Motoworks (Chicago) re-did my rebuild, and adjusted the float levels. Voila! The bike now keeps up with interstate traffic without a problem. Fuel depth in the bowls should be 18-22mm when the floats are properly adjusted. Yours feels like its running out of gas because it probably is.
    Khittner,
    I don't think those numbers are correct. According to Bob Fleischer, aka Snowbum, the depth depends on if the carbs are 32 mm (64/32) or 40 mm carbs (94/40). Here is his quote from this article: https://bmwmotorcycletech.info/bingcv-2.htm.
    "For the 32 mm carburetors, use 24 mm fuel height. For the 40 mm carburetors, use 28 mm fuel height. "
    I believe this bike has the 40 mm carbs. In any event, Bob's recommendations are for deeper fuel levels than you state.
    In this article, https://bmwmotorcycletech.info/earlybingr75cv.htm Bob says the "early" /5 carbs (I believe this is the 64/32/3 and /4 models) have a recommended fuel level that is lower, 19-20 mm.
    "... you can measure the fuel depth in the float bowl decently enough. Optimum from the center bottom middle depression area of the bowl, to the fuel level, is 19 to 20 mm. This is for the stock one piece floats!"
    I hope this helps.
    Best.
    Brook Reams.
    Brook Reams - Arvada, CO
    Endeavor to Persevere
    Various Two-wheeled Vices, All BMW || Website: Airhead Rebuild Projects
    2004 R1150-RS||2002 F650-GS||1983 R100RS||1977 R100RS||1973 R75/5
    Registered User Guenther's Avatar
    Jan 2007
    Colorado Springs, CO
    I had the very same symptom on a car only when in the top gear. I didn't believe it when the mechanic said it's a spark plug wire.
    Argued with him! But after he replaced the wire the problem was gone and never re-appeared.
    He explained it to me that in the higher gear this spark plug failed - due to the bad wire - to always cause an ignition.
    /Guenther
    2017 F700GS
    Jun 2007
    Portsmouth, NH
    I would check the gas tank breather as well.
    Quote Originally Posted by Anyname View Post
    I opened the tank lid at cruising speed and it didn't change the behavior so it's definitely not a vacuum lock in the tank.
  1. 96 R1100GS loosing power at speed
    By fishbmw in forum Oilheads
    Last Post: 06-24-2018, 10:55 AM
  2. '77 R100/7 high speed stumble
    By norton in forum Airheads
    Last Post: 02-09-2018, 05:24 PM
  3. high speed whistle
    By connellyt in forum F-Twins
    Last Post: 06-20-2017, 01:56 AM
  4. R100/7 high speed hesitation
    By blackwater in forum Airheads
    Last Post: 03-16-2009, 06:43 PM
  5. loss of power at high speed "75 r90/6
    By soflopro in forum Airheads
    Last Post: 04-02-2008, 03:55 PM
