Results 1 to 12 of 12
Thread: Auto windshield function
    Jul 2018
    Prairie City IA
    I recently noticed that the windshield on my 2018 RTW doesn't go down when I shut the bike off. Doesn't matter if the kickstand is up or down. I can't see that there is a setting that disables this function. It will go up and down manually just fine.
    Any ideas?
    Never get to busy making a living that you forget to make a life.
    2018 R1200 RT- 26.5K miles and counting
    Are you shutting off with lol switch, kickstand or ignition? Only shutting off by ignition will return screen to low/resting position.
    Jul 2018
    Prairie City IA
    Quote Originally Posted by skewzme View Post
    I shut the bike off with the switch.
    Maryland
    What is an lol switch?
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
    Registered User skibumwi's Avatar
    Jul 2016
    Milwaukee
    Quote Originally Posted by kioolt View Post
    Lap Of Luxury?
    Mine always lowers on shutdown, regardless of method.
    Good luck!
    Jul 2018
    Prairie City IA
    Quote Originally Posted by rxcritical View Post
    Good luck!
    Mine did to until about a week ago. Looks like a dealer visit is in order.
    Maryland
    Quote Originally Posted by skibumwi View Post
    Lap Of Luxury?
    I think it might be a laughing out loud switch.
    AMA,BMWRA,BMWMOA
    Jan 2017
    Bothell, WA - USA
    Pretty sure skewzme means the emergency red rocker "Stop" switch |x| or |o| on the right grip.
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    Mine goes down when I turn off the ignition. The kill switch just stops the engine. The same with the side stand.
    Pat
    Ride Safe!
    '16 RT
    Yeah, I meant kill switch, but auto correct didnít want any violence in my post so changed it to laughter.
    Quote Originally Posted by lstayner View Post
    Any ideas?
    Last week, the windshield on my 2015 RT stopped the automatic "retraction(?)" when I shut down the bike. In the OM, there is a reference made to a "pressure-sensitive finger guard" function that will keep the windshield from dropping if there is some resistance. This weekend I had the opportunity to spend some time on the problem. I started taking apart the the system and after each step, I would power up the bike to see if there were any changes. Once I removed the windshield carrier brackets, everything began to work as normal.
    I realized that last year, when I noticed a squeak during operation of the windshield, I had applied a small amount of grease to the stainless steel pins that connect the windshield motor arms to the carrier brackets. The repair manual does not call for lubrication but since it was squeaking, why not add some lube . I cleaned up the pins which seemed like they were sticky, put everything back together and everything is right with the world.
    Lesson learned
  1. Test function of ESA II suspension ?
    By mattias_k1300 in forum Wedge K-bikes
    Last Post: 12-26-2017, 01:55 AM
  2. Search function question
    By romany in forum Forum Software Specific Help. NOT for bike related questions.
    Last Post: 12-05-2014, 08:12 PM
  3. Throttlemeister function
    By KevinRT in forum Gear
    Last Post: 04-14-2011, 01:19 PM
  4. BMW Zumo XM Radio Function?
    By rab1957 in forum Gear
    Last Post: 11-19-2009, 09:46 PM
  5. The Forum Search Function
    By ljjohns in forum Forum Software Specific Help. NOT for bike related questions.
    Last Post: 09-06-2009, 12:47 AM
